New fuel module test results and thoughts
Postby rollinhome [OP] » June 17th 2011, 5:59pm
I have a 98 safari, v-6, 2whd, I have written here about an intermittent condition of power loss. various computer analysis indicated a cat problem though that ended up not being true. fuel presure tests where 52 lbs at idle with no movement during accel. after testing many items: ig mod, coil, new plugs and wires, removing the cat, i decided to change out the fuel module.
results. I drove for several weeks testing the performance and fuel pressure. the loss of power never occurred again and the fuel pressure while still hit 52 at idle, rose to 56-58 lbs under load. feeling comfortable of it's reliability, i took the van on a
2400 mile trip, to see the country and visit some friends.
the engine performed flawlessly in regards to the loss of power. mpg was better, which i found interesting since my understanding is that the engine was starving for fuel and now was getting more.
after 1500 hundred miles it did develop a slight miss fire during the warm up period that went away after 15 min. this seems to correspond to moisture conditions and so i am going to check the plug/coil wires, moving through the ignition system one by one.
I did purchase the fuel module from the gmparts guy out east, referred to by people on this list. it was delivered quickly and as we know, was less than half the price of my most reasonable parts center here in chicago.
I am so thankful to this group for all your thoughts. I was close to giving up.
side note. since i had cut the cat out, the van would not meet emission standards here and thus was unlicenseable in chicago. so, on my trip i registered the van in alabama. this saved me huge dollars on exhaust system repairs. currently the exhaust is std with a gutted cat.
rollinhome
Years of Membership: rollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full yearsrollinhome has been a member for 11 full years
Extra Info: WINDOWS WITH BED
  • 4.3L V6 Hesitant To Start When hot - Fuel Pressure Test
    by K-TRON » November 5th 2020, 4:42am in Engines
    November 17th 2020, 3:05am
  • Chronic ignition module failure
    by Bikley » July 1st 2020, 4:38am in Engines
    Last post by Big_kid View the latest post
    July 13th 2020, 3:45am
    37
    November 25th 2020, 2:55am
Re: New fuel module test results and thoughts
Postby Leeann_93 » June 17th 2011, 9:53pm
Glad to hear you've got her running well :)
Postby MattB » February 26th 2020, 5:08am
What VIN Code is the 4.3? I recently i stalled a 2002 MPFI unit on my 99'. The performance increase was amazing 20-23 MPG. My originally equipment was a CSFI unit with those troublesome Poppet Valves on the ends. They tend to clog and stick, P0171 and P0174 codes, lean Bank 1-2. I'm outside of Chicago were using the 10% Ethanol Fuel, it clogs things even faster.
Maybe weld on a CAT and get the Fuel Trim working. Your wallet will thank you at the Gas Pump.
Best Wishes, MattB.
"Which is worse, The Evil you know or The Unknown?"
MattB
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: MattB has been a member for 3 full yearsMattB has been a member for 3 full yearsMattB has been a member for 3 full years
Images: 20
Alias (AKA): MattB
Extra Info: Rwd SLE
Postby Leeann_93 » February 26th 2020, 5:14am
I get that you’re excited, but this is a 9-yr-old thread...
It is currently November 25th 2020, 2:55am
Attached by: Slime
Slime
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
K-TRON
Comments: 23
Date: Nov 12 '20
Time: 2:51am
Devonian
Date: Nov 11 '20
Time: 10:25pm
Users browsing this forum: Google Adsense [Bot] and 25 guests
