Oil pressure gauge dropping and rising and fluttering
Postby thelackof [OP] » September 16th 2017, 3:16am
Chevy Astro 2000 passenger
The oil gauge is up and then the check gauge light comes on as the gauge begins to notch down, until dropping to 0 and sitting there.
When this happens, a fluttering, knocking, ticking sound comes from the front hood.
I've checked before and it sounds like it's coming from where a belt is.
I'm no expert.
but I had a slight oil leak when I first bought the van maybe 9 months ago and since this started happening, my oil is almost out in about a week before I have to add more.
but very recently, it hasn't been going out as fast as it was a week or so ago.
What could be causing this? and thank you!
thelackof
Years of Membership: thelackof has been a member for 4 full yearsthelackof has been a member for 4 full yearsthelackof has been a member for 4 full yearsthelackof has been a member for 4 full years
Topics: 17
Extra Info: LS 2WD
  • Oil Pressure Specs
    by AveryStella » December 20th 2020, 12:52am in Engines
    December 27th 2020, 1:57pm
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    9
    55
    March 1st 2021, 10:38pm
Re: Oil pressure gauge dropping and rising and fluttering
Postby AstroWill » September 16th 2017, 6:10pm
Sounds like you are low on oil, or have an oil pump/pickup problem. But if you are still running it like that, you probably have quite a few more problems than that now ;)
Images: 472
Postby Mmusicman » September 17th 2017, 1:59pm
If your oil pickup tube has broken/fallen off... then it will be even MORE important to keep your oil level completely topped off (or even a little higher than normal) until you fix it. Usually when this scenario happens, you will see oil pressure drop to zero on hard stops, as oil sloshes forward away from oil pump.
If this were not the case, it could have been a bad oil sender, or intermittent wiring connection to it. If your gauge is "rapidly" fluctuating... this would usually be the case.
I've had both scenarios happen to me over time.. very different... pretty easy to diagnose.
But since you describe lifters ticking (when pressure drops)... you definitely have an actual low oil pressure problem. As Will stated.. keep driving like this and you will have even bigger problems!
Topics: 73
Images: 49
It is currently March 1st 2021, 10:38pm
Attached by: MHM
MHM
Date: Today
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Users browsing this forum: Yandex [Bot] and 32 guests
