Odd Fuel Issue... 0455 Code
Postby wyomad [OP] » September 17th 2017, 4:57pm
Hey all, I have an odd finding with my 05 AWD LT. When I start it up, sometimes it will stall right away if i don't keep my foot on the gas slightly. The idle drops drastically if it does stay running on its own, and every now and then while moving slowly (like parking lot speeds) the steering will become difficult and will almost....or will...stall. The OBDII scanner is throwing an 0455 code, or gross evap leak, and the SES light comes on. Its the only code. Other than that the van runs great while driving.
The other day I bought a new vapor vent valve/ solenoid for it hoping that was the issue. Like an idiot I backed over the new one in the driveway so unfortunately did not get to install it. I had unplugged the electrical connector from the current one and blown some dust out of it, and as I ruined my new one I had to plug the current one back in. Van seemed to run better and my SES light was no longer coming on. Fantastic right?
Well here's what I noticed yesterday. Yesterday was payday and as I commute to work the first thing I do is fill my tank up with gas. Everywhere I've read on the internet says my van should have a 27 gallon fuel capacity... but when I fill it up it apparently only takes 13 gallons. The fuel gauge says its full... and when I do fill it up....it starts stumbling, stalling, and generally running like sh!t at low speeds or on startup again.
Why would my tank only be filling to half capacity?? The fuel tank is not dented or crushed... so I would imagine that would be because of the part I was going to replace (the little box on the D/S rail), but if that was the faulty part would it also cause the fuel gauge to falsely read full?? Is the vapor vent valve also responsible for the gauge reading or is there a float arm built in to the fuel pump? I'm hoping that if I know which parts are responsible for these issues I can pinpoint which ones to replace.
Anyway, I am just hoping someone knows what's causing these symptoms so I can tackle it and make my van less annoying to drive. Thanks for the help and van on!
Fuel pump. It has to be the fuel pump right?
wyomad
Years of Membership: wyomad has been a member for 3 full yearswyomad has been a member for 3 full yearswyomad has been a member for 3 full years
Images: 4
Re: Odd Fuel Issue... 0455 Code
Postby AstroWill » September 17th 2017, 6:07pm
Just an FYI, you can edit your post for 24hrs instead of posting another reply.
Images: 471
Postby wyomad [OP] » September 17th 2017, 6:41pm
Apologies for the inconvenience.
wyomad
Images: 4
It is currently February 26th 2021, 4:34pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Yandex [Bot] and 21 guests
