While my 91 Astro with TBI starts right up and runs/drives in a manner that would be acceptable to many, there are a few issues. When I first got it, there were a bunch of little running issues, wonky shifting, etc. I've done quite a few simple things to rule out the obvious stuff but still a few things remain. I'll give a list of what already has ben done and then a list of details of the problems.
This whole list was done all at once, so I'm not sure what fixed what, but everything is much improved! Shifting is now just about what I would expect and overall driveability is much better. So far I Have:
A) Oil and all filters changed/replaced.
B) New plugs, cap, rotor and wires. Plugs were all fairly even/similar, with two just a tad darker than the others. None were wet or oily. No noticeable misfires or apparent engine skipping.
C) All vacuum hoses replaced and firm connections confirmed, to rule out a hidden leak. The hose to the PCV valve was broken right off and crumbly. I suspect this was at the root of the wonky shifting issue, as well as some of the other issues. I do suspect that most/all problems are vacuum related, as in something leaking or in the sensing of vacuum, "Somehow, Somewhere, Someway," a cool Kenny Wayne Shepherd song, BTW!
D) Put in two full bottles of Seafoam into about 1/2 tank of fuel (for an estimated ratio of +2 ounces of Seafoam per gallon), drove for about 40-50 miles of varied conditions, stomping on it, etc, then topped off the tank and have driven another couple hundred miles. Man 'O' Man, that Seafoam is some kinda magic potion!
Now here's a detailed description of the maladies, bearing in mind that the issues become more pronounced when the AC is on. I do live in Las Vegas, so AC is kind of a necessity! Also, all the same problems were much more dramatic before doing all of the above, but still exist, to some degree.
1) Upon cold startup, it runs well, but exhibits a somewhat random surging of idle speed. Not really drastic, but noticeable and it mostly clears up as the engine reaches normal operating temperature.
2) With light to medium acceleration from a stop, after each "up shift" it seems to bog for a second, +/-, and then picks right back up. There is no noticeable engine skip/misfire, just a slight hesitation/bog. It is more apparent/dramatic on the 1 to 2 shift than on the 2 to 3 shift. Since doing all the above steps, it is almost non-existent with the AC off.
3) When stopped at a light, in gear, it runs as smoothly as these engines can, but then "hiccups" followed by a short surge and then runs smooth again. Before performing the above stuff, it would happen at shorter intervals, but now it needs to be a fairly long light for it to happen.
4) Driving at a steady speed, either 30-45 in non-overdrive or on the highway, I feel the engine randomly and slightly bogging and then picking up, with intervals ranging from probably 1/4 second to 2 seconds. Upon acceleration, this mostly goes away. This no longer happens at all with the AC off, but still occurs with the AC on and it feels exactly the same as if I cycle the AC on and off at the controls. I know that some vehicles have some sort of sensor/AC compressor switching system that turns off the compressor when vacuum drops under acceleration, but am not sure if that type of system is on my truck, or what the parts are that operate such.
Please understand that I have no problem spending $$$ on anything that actually needs to be done, but am not well off enough to simply, randomly and willy-nilly, "throw parts" at this van until the problem goes away. I'd be much happier to go at it piece by piece and in the correct and most efficient order, in hopes of not only fixing my issues, but also learning and understanding what each part does and how to recognize each part's failure in the future.
Thanks Crazy Guys & Gals,
Gene
