No start in the cold after oil change
Postby turntupturnipturntupturnip is online! [OP] » January 16th 2018, 3:26am
We had a freak 55 degree day last week, surrounded by sub freezing temperatures. I used it as an opportunity to change the oil on both my vehicles. I started up the van afterwards, and let it run for a minute or two. This was 4-5 days ago. I haven't tried to start it since. Today, it is in the 20s and won't start. It turns over and occasionally sounds like it is going to start up, but keeps falling short.
I know that there are a lot of things that could be causing the problem, but I am wondering if it could be tied to the oil change. It has started in colder temperatures this winter, already.
PS. This is the first oil change that I've done on the van since I've owned it. I bought it this summer but haven't driven it more than 300 miles.
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: turntupturnip has been a member for 3 full yearsturntupturnip has been a member for 3 full yearsturntupturnip has been a member for 3 full years
Topics: 13
Images: 6
  • Hard Cold Start and Rough Idle. No Codes. Diagnosis?
    by AstroTan » October 17th 2020, 5:26am in Engines
    Last post by AstroTan View the latest post
    December 31st 2020, 5:53pm
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    35
    March 7th 2021, 7:22pm
Re: No start in the cold after oil change
Postby jmderyke » January 16th 2018, 3:47am
I'm sure you know what you're doing when it comes to changing oil and you used the normal weight oil for the vehicle.
So I'd look at the battery voltage since its cold, after that if it doesn't start look at the fuel and ignition system.
jmderyke
Years of Membership: jmderyke has been a member for 3 full yearsjmderyke has been a member for 3 full yearsjmderyke has been a member for 3 full years
Topics: 21
Images: 2
Alias (AKA): jd
Extra Info: 4x4 lifted
Postby CopperFiremistCopperFiremist is online! » January 16th 2018, 3:51am
My first guess is it has moisture under the cap. Pull the cap and have a look. Make sure your battery is up to the job as well.
Pullin The Pass
Firing on 1 Cylinder (L2)
Years of Membership: CopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full years
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby turntupturnipturntupturnip is online! [OP] » January 16th 2018, 3:58am
I just replaced the battery at the beginning of the season with a bigger capacity battery than was in there before.
There is no moister under the cap currently, but if there was water in the system, it would be ice.
I used 5w30. I'm in Michigan. The battery gauge looks good, but I can check it with a multimeter in the morning.
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 13
Images: 6
It is currently March 7th 2021, 7:22pm
OldSchoolNoeOldSchoolNoe is online!
Comments: 9
Date: 12 minutes ago
Time: 7:10pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Users browsing this forum: No registered users and 30 guests
