Engine get very hot even the temperature gauge shows normal!
Postby WhiteAstro [OP] » January 17th 2018, 3:32am
Hi all,
My van engine get very hot and even feel burning heat from side of the van. The dashboard temperature gauge shows around 190f which is normal. (Right?) I think the gauge is working because it goes to middle from cold start slowly.
The coolant was low so I added 1 gallon of distilled water. Dont recall if it acted same before I add the water.
Is it normal or I my van has a issue? :confused:
As always really appreciate all you suggestions,
Ned
WhiteAstro
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: WhiteAstro has been a member for 3 full yearsWhiteAstro has been a member for 3 full yearsWhiteAstro has been a member for 3 full years
Topics: 7
Re: Engine get very hot even the temperature gauge shows nor
Postby chevymaher » January 17th 2018, 11:53am
More info please. Better description. Reasons you feel it is to hot.
Is it the engine getting to hot or the exhaust? Feel the intake carefully when gauge says it is full operating temp. Is the exhaust hot glowing after driving?
Hot is subjective. A thermal heat gun pointed at things would help. Freight by the bay has them cheap.
If the engine isn't boiling water. Popping sound in the cooling system after driving chances are it isn't to hot. Is the system properly burped of air. A air bubble in the cooling system in the intake can give false readings. But usually it is the temp reads to low there and the heads are getting way to hot.
If the exhaust is getting to hot it probably is running to lean.
Anywho check into it more and report findings.
Postby WhiteAstro [OP] » January 17th 2018, 5:04pm
Thank you for you suggestions Chevymaher, I will get infrared thermostat measure engine.
WhiteAstro
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 7
It is currently March 7th 2021, 3:30pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
