Odd Problem
Odd Problem
Postby alexalexanders [OP] » October 20th 2011, 2:24am
Ok odd problem here. Yesterday while i was merging into traffic i had to floor the van(idiot driver) and then slam on the brakes for a red light, problem was as i am coming to a stop the van starts running terriable. SES light comes on, its barely running i tap the gas it dies. Put it in park and it wont start back for about two or three tries< then it fires up but is idling REALLY high, like i had the pedal pushed down a little. Its running fine besides the high idle, the ses lights off and when i drive away it runs fine. :confused:
Stopped and bought some fuel injector cleaner just in case and drove it another 25 miles and it ran great. Today on the way home when i pull to a light it starts misfiring but not even close to a bad as previous day. Any ideas on whats the problem? Oh btw van has new plugs, wires, cap, rotor, coil <all ac delco, and a new wix fuel filter. The fuel pump also delphi has about 24k on it and is roughly 1.5 yrs old :ty:
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
  • Accessory belt problem & engine dies at idle
    by SlowRider » September 15th 2020, 8:38pm in Engines
    Last post by SlowRider View the latest post
  • Starting problem when wet outside
    by thomasebud » December 31st 2020, 6:33pm in Engines
    Last post by astroracer View the latest post
    January 2nd 2021, 5:14pm
    19
    March 6th 2021, 9:52am
Re: Odd Problem
Postby chevymaher » October 20th 2011, 2:45am
I cant say for sure.But it sure sounds like a dirty sticking injector.Fuel not atomizing correctly,droplets.Flooding the engine.It idling up to burn the gas in the intake,because the computer reading way to rich.Thats my best guess since I cant be there to play with it and see.
Re: Odd Problem
Postby RECox286 » October 20th 2011, 9:44pm
Sounds like a good place as any to start. See if there are any codes. Read and clear them if there are any. Drive the truck and see what continues to happen, reread codes.
Let us know what you find.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Odd Problem
Postby alexalexanders [OP] » October 21st 2011, 1:45am
Ok drove about 50 miles today with no problems. Had mechanic friend use a scan tool on it and there was no codes. I think the fuel injector cleaner was the fix, its been about 5000 miles since i have ran any so i think i got some dirt in the fuel injectors and the cleaner fixed it! I drive about 50 miles per day mon-fri so ill post if i have anymore problems.
http://www.lucasoil.com/products/displa ... 8&loc=show
This is what i used
2000 GMC Safari SLE
alexalexanders
Topics: 80
Re: Odd Problem
Postby redfury » October 21st 2011, 3:34am
I was going to suggest that perhaps the huge jog on the fuel tank dislodged some debris and was causing the problem....the fuel injector cleaner perhaps dissolved it
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Re: Odd Problem
Postby cowboydan » October 22nd 2011, 1:08am
combo of flooded and dirty. have a friend follow you on the highway. put your foot to the floor and have your friends passenger take footage of what comes out of the tail pipe. post the vid. i would recomend intake medic regardless
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
It is currently March 6th 2021, 9:52am
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
