Overfuelling on my 4.3 TBI
Postby Chop [OP] » February 22nd 2018, 8:23pm
Ok guys- overfuelling problem...
'87 4.3 TBI hasn't been on the road for 10 years, I've replaced: plugs, leads, dizzy, oil pressure sensor, temp sensor (driver's side head) MAP sensor, PCV valve and all vacuum pipes connected as per diagram.
She's bollocking that much fuel through her I've had to turn the dizzy almost 50/60 degrees anticlockwise from #1 at TDC on compression stroke to get her to run. After running for a while she seemed to settle down a bit ( like it came off of choke?) But then after turning her off to connect up timing light she wouldn't start again. Eventually after keep pulling the fuel pump fuse out to try and balance her into running and idling, it seems according to the light she was 40 degrees anticlockwise, which we turned slowly clockwise and got to 15 degrees before she just cut out.
My mechanic thinks that we're not going to be able to set the timing properly until the fuelling is right as we're just compensating for it.
Has anybody else had this problem and am i missing something obvious??
Also on disconnecting the tan and black wire the manual says about, she just won't run at all.
Any constructive help is welcomed here! Thanks in advance :chevy:
Chop
Years of Membership: Chop has been a member for 3 full yearsChop has been a member for 3 full yearsChop has been a member for 3 full years
Van Model Year: 1987
Extra Info: 4.3 TBI Shorty CS
  • TBI Injectors,, same part for each side?
    by bowtie262 » September 11th 2020, 2:51am in Engines
    Last post by markmitchmarkmitch is online! View the latest post
    September 14th 2020, 3:45am
  • 92 astro 4.3 cmfi to tbi question
    by Quelany » September 15th 2020, 12:02pm in Engines
    September 15th 2020, 2:51pm
    95
    February 25th 2021, 5:26pm
Re: Overfuelling on my 4.3 TBI
Postby AstroWill » February 22nd 2018, 9:16pm
Getting a nice spray from the injectors? What is your fuel pressure? Ensure plug wires are correct. IAC working properly?
Images: 471
Postby Chop [OP] » February 22nd 2018, 10:20pm
AstroWill wrote:Getting a nice spray from the injectors? What is your fuel pressure? Ensure plug wires are correct. IAC working properly?
No the injector spray isn't brilliant to be fair, only when it's full on spray
Plug wires are fine, IAC seems fine as it was idling nicely before choking itself out
Unaware of fuel pressure, what should it be?
Chop
Postby AstroWill » February 22nd 2018, 10:38pm
9-14 running, but I shoot for the higher side. Injector spray should be a nice cone shape.
Images: 471
Postby Big_kid » February 23rd 2018, 3:07am
I found it easier to see the injector spray pattern when it's illuminated by a timing light.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby Chop [OP] » February 23rd 2018, 8:22am
AstroWill wrote:9-14 running, but I shoot for the higher side. Injector spray should be a nice cone shape.
It is cone shaped when it's pissing through, but when it had settled it was a bit messier. Does mine have a fuel pressure regulator? If so where's it located?
Chop
Postby markmitchmarkmitch is online! » February 23rd 2018, 1:36pm
On the injector pod in the back right behind the two injectors its kind of rocked in under the top . I would normally have a pic to show but I am on a small tablet on vacation. Google GM TBI fuel pressure regulator you may get a picture. If the regulator is bad it could be the problem.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
Postby Chop [OP] » February 23rd 2018, 6:35pm
markmitch wrote:On the injector pod in the back right behind the two injectors its kind of rocked in under the top . I would normally have a pic to show but I am on a small tablet on vacation. Google GM TBI fuel pressure regulator you may get a picture. If the regulator is bad it could be the problem.
Thanks mate I've been researching it and can see where it is now so that will be on my to do list
Chop
Postby AstroWill » February 23rd 2018, 7:42pm
Get the entire rebuild kit for the TBI while you are in there, it's cheap and once you start pulling things apart...
Images: 471
It is currently February 25th 2021, 5:26pm
Ken2.7
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: No registered users and 20 guests
