Engine question
Engine question
Postby markmitchmarkmitch is online! [OP] » July 7th 2018, 2:17am
Ok I have rebuilt a few engines over the years but I have never had to change valve springs so my question is: The old springs have a flat steel spring inside of the round spring but the new springs do not am I suppose to remove them from the old springs and install into the new springs? Little bit of history: engine was a stock 1991 350 TBI from a silverado. I am using the 193 heads but they are now ported and polished . The reason i am changing the springs is because I have installed a LT1 full roller cam from a Buick Roadmaster and the new springs are matched to the cam. Yes I installed all the parts to convert it to the roller cam. Thanks markmitch
Firing on 2 Cylinders (L6)
Topics: 580
Images: 20
Extra Info: RS V8
  • Good operating (engine running) fuel pressure?
    by gman » March 22nd 2020, 7:11am in Engines
    March 28th 2020, 4:26am
  • Repair or swap my engine?
    by G-MO218 » March 28th 2020, 7:44pm in Engines
    March 29th 2020, 6:18pm
    24
    July 9th 2020, 3:27pm
Re: Engine question
Postby 90safari » July 7th 2018, 2:28am
I don't think so. I say that because the roller lifters are easier on the rocker arms and spring assemblies, and valve train in general. They don't have the old harsh cam lobe ramps of the flat tappet cams, so you shouldn't need the extra spring.
I didn't see any extra springs in the heads of my roller 4.3 that I just installed in my van a couple of weeks ago. It's a 92 engine.
867378671386681
90safari
Blue Status (L2)
Blue Status (L2)
Years of Membership: 90safari has been a member for 6 full years90safari has been a member for 6 full years90safari has been a member for 6 full years90safari has been a member for 6 full years90safari has been a member for 6 full years90safari has been a member for 6 full years
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Re: Engine question
Postby multimoto » July 7th 2018, 2:49am
^what he said ^
unless youre planning on revin' the piss out of it. they might help get a few more revs out of it before the valves float but if you use them, be sure to check for coil bind and check spring pressures @ various lifts and compare to the cam specs if you have them.
Edit to add: oh.. stock camshaft.. use only the springs that came with it. BTW some racers use triple springs.
'87 GMC Safari Explorer
multimoto
Years of Membership: multimoto has been a member for 2 full yearsmultimoto has been a member for 2 full years
Topics: 12
Images: 369
Van Model Year: 1987
Extra Info: Explorer
Re: Engine question
Postby markmitchmarkmitch is online! [OP] » July 7th 2018, 5:20am
ok thanks , I never thought about the roller being easier on stuff, and no I am not reving it I am using my van to travel not for racing lol.
Topics: 580
Images: 20
Extra Info: RS V8
Re: Engine question
Postby chevymaher » July 7th 2018, 11:54am
Yes Mark use it. It keeps the springs from binding and grinding against each other. They don't include it because it is considered a non wearing part.
Re: Engine question
Postby markmitchmarkmitch is online! [OP] » July 7th 2018, 3:37pm
Wow ok that sounds like fun. LOL
currently I am porting and polishing the TBI heads according to the video's I found on you tube. I also ported/port matched the intake and the exhaust manifolds. Every little bit helps when you have to deal with smog laws. mark
Topics: 580
Images: 20
Extra Info: RS V8
Re: Engine question
Postby sixsix » July 7th 2018, 5:58pm
markmitch wrote: ... you have to deal with smog laws. mark
Profound statement there.
By the way - how'd that transmission build turn out ? You're stayin' green , Right ?
Mike
Well, after all... what would Banacek say ?... "When will there be a "Cultural Change” in the Nautilus and Whatilus population for a change - it's always the White man’s systems and culture that must be guilty and make stupid concessions.”
Orange Status (L5)
Orange Status (L5)
Topics: 36
Images: 1214
Re: Engine question
Postby markmitchmarkmitch is online! [OP] » July 7th 2018, 7:01pm
Transmission was a failure at first fluid leaked all over the floor of garage but I took it back out and took it about 80% apart realized I had a broken snap ring so I ordered new snap rings and put it together again. Now it shifts super good and at 35 mph when I punch the gas pedal it broke the tires lose. LOL I may have to rebuild another one in the future cause my wife wants me to build a late 60's early 70's truck next. So my pre plan is LS engine 4L80 trans but leave the exterior looking stock. But of course (for my back) bucket seats from a newer vehicle. I checked on the LT1 site and the stock valve springs do not require a damper spring thats factory.
Topics: 580
Images: 20
Extra Info: RS V8
Re: Engine question
Postby Mmusicman » July 7th 2018, 8:26pm
markmitch wrote:..am I suppose to remove them from the old springs and install into the new springs? ..
I never have, and I don't think you are supposed to. However, I don't know that there is any harm either, and it might even be marginally beneficial. But the benefit is probably inconsequential, or the spring suppliers would probably include them. It may be like some "stock" parts you remove and throw away. It might also slightly affect spring rate and seat pressure specs, but again probably not enough to matter. Don't know for certain... but I've always tossed old worn parts that could potentially break.
But it's a good question.. one that maybe someone might have a more definitive answer to.
Firing on 3 Cylinders (L5)
Topics: 71
Images: 49
Re: Engine question
Postby sixsix » July 8th 2018, 6:23am
Lots of answers thereya'
Probably a correct one hidden in thereya'
Sowhoya' gonna' believe?
LOL - Sounds like a fun build - hope it stays thataway.
Mike
Orange Status (L5)
Orange Status (L5)
Topics: 36
Images: 1214
Re: Engine question
Postby multimoto » July 8th 2018, 6:39am
sixsix wrote:Lots of answers thereya'
Mike
WWBD?
What Would Buick Do.
lol
multimoto
Topics: 12
Images: 369
Re: Engine question
Postby AstroWill » July 9th 2018, 8:50pm
markmitch wrote:Ok I have rebuilt a few engines over the years but I have never had to change valve springs...
Is that related to an Italian tune-up?
Topics: 106
Images: 437
It is currently July 9th 2020, 3:27pm
Yuip
Time: 5:11pm
Comments: 14
Date: Jul 07 '20
Time: 6:27am
Comments: 9
Date: Jul 03 '20
Time: 6:15pm
Star Stuff
Comments: 87
Date: Jul 03 '20
Time: 4:22am
Attached by: ri$e*above
ri$e*above
Date: Jul 03 '20
Time: 1:14am
Users browsing this forum: tonydobbstonydobbs is online! and 12 guests
