Engine stumbles with moderate throttle, and when that happens temp gauge momentarily spikes and quickly returns to normal.
Runs fine cruising, and if I'm very gentle with throttle engine stumble and temp gauge spike dont occur.
I'm thinking perhaps as the engine responds to throttle, it moves enough due to torque that its lifting a ground and causing the
engine stumble and the temporary spike of temp gauge ( which is very quick up and down )
Was going to add some braid to ground engine to chassis in a couple spots and see if that helps.
any other thoughts as to possible cause / fix would be greatly appreciated.
2003 Astro AWD extended 173k miles
