I am a newbie here, but found your site a while ago and have been lurking thru posts to help fix issues when needed. I have owned 3 astros now, bought a new 95, used 01 and currently have another 95 with 217K mi. For all the info I am planning to list, probably going to be a long post.
About 3 weeks ago, van had been running great. Wife drove it home on a Friday night and all was good. Wife went out Sat morning and van would crank over, but not fire. When I got to it, same thing crank, no fire.(Temp overnight did drop into the 20's) Pulled things apart and hooked up fuel pressure gauge, 60psi(fuel pump AC Delco about 1 yr old) pulled coil wire from Distr, good spark. reconnected wire, pulled #4 wire laid wire against manifold, cranked engine and it started. shut engine down and restarted engine, but now running rough. (About 13 mo ago did complete tuneup including plugs, wires, cap, rotor and real issue at that point was ignition module.) Shut off and restarted several times, restarted without fail, but ran rough. took van to in laws(about 2 mi) and let it run(about 10 min idle) to see if it would come out of it, stall, anything to help troubleshoot. No luck. Drove back to house but noticed lack of power. Changed spark plugs, no change. Couldnt find reason, so decided to "let it ride" as wife works in town and would look at it later when issues arise again.
Well, Monday wife was headed to work when van just died while driving and would not restart. Went by lot van was in to see if it would start, hit a bit right at start, but would not light, just crank. finally go to look at it today. again checked fuel pressure, 60psi. checked for spark and saw leakage where wire enters boot on coil wire, went to parts store got new wires. Coil now nice blue spark, with no spark at plugs, Ohmed pick up coil-good, Van has NO crank sensor, took ignition module loose found a bubble on top, got new replacement, no spark. bought new cap and rotor with brass terminals, spark, but no run. checked oil pressure sensor, could not get 1 Ohm reading at 0 psi, replaced with new, still no start. Finally poured fuel down intake and got van to fire, ran rough and when trying to give fuel puffed big cloud of smoke out intake. After several restarts van runs fantastic, smooth. Did notice that fuel pressure while running was about 55-57 psi. Went back to store and bought new fuel filter as it was not replaced when I did pump approx 1 year ago. Going to change it and see if pressure improves. I am going to let van sit overnight and see what it does in the morning, if no start will put fuel down intake again to see if it will fire again.
This is where I am at. Also I changed spider about 1 year ago also. Sure there is probably something I have checked and forgot to post. Still not sure what fixed the issue for the moment. Any ideas would be greatly appreciated.
Chad
