4.3L Engine Crossreference
Postby HootenWeb [OP] » April 20th 2019, 1:29pm
Hello fellow Astrosafarians,
I have run a search on the forum for "engine" + "cross" trying to figure out what year 4.3L engine will work for my 99 as I look for a donor. I read every single post where someone said "crossed my mind" and "engine"... :banghead:
Is there a post already covering this that I just can't find? Or am I searching the wrong thing?
Thanks to Wikipedia I have this info:
85-86 LB1 4BBL
86 LB4 TBI - Unique to this year
87-92 LB4 TBI
90-92 LU2 TBI
92-94 L35 CPI
95 L35 CPI - Unique to this year
96-02 L35 SCPI
03-05 LU3 MPFI
So based in this I would say I am safe with any 4.3L from 96-02. Is this correct?
What about blazer, Jimmy, Sonoma, bravada or S10 motors? Same years?
Swap my intake manifold with a new gasket and life should be good... Is this correct?
I have a 2002 AWD hi-top with a good motor and have been contemplating borrowing that and looking for an LS for it but only want to go down that road if it will work. I can't have two down vans or SWMBO will have me living in them.
Thanks for any and all help.
~Webster
HootenWeb
Years of Membership: HootenWeb has been a member for 1 full year
Alias (AKA): Webster Hootenheimer
Van Model Year: 2002
Extra Info: 4.3L AWD HighTop
  • 4.3l rebuild - cam options
    by doogaloo » July 28th 2020, 3:04am in Engines
    July 28th 2020, 11:15am
  • dash panel goes bonkers engine quietly shuts down.
    by unclemaui » May 29th 2020, 2:21pm in Engines
    Last post by unclemaui View the latest post
    June 4th 2020, 5:38pm
    October 29th 2020, 12:57am
Re: 4.3L Engine Crossreference
Postby markmitch » April 20th 2019, 4:20pm
Let me look and see if that info is still on my old computer and get back to you, Mark
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby HootenWeb [OP] » April 20th 2019, 6:44pm
markmitch wrote:Let me look and see if that info is still on my old computer and get back to you, Mark
:thumbup:
:rockon:
HootenWeb
Postby Huckleberry » April 20th 2019, 7:06pm
'93 GMC Safari Cargo Shorty, "The Creeper" (work)
'92 Chevy Astro Passenger Shorty, "The Classtro" (play)
Huckleberry
Years of Membership: Huckleberry has been a member for 4 full yearsHuckleberry has been a member for 4 full yearsHuckleberry has been a member for 4 full yearsHuckleberry has been a member for 4 full years
Topics: 24
Extra Info: RWD
Postby Leeann_93Leeann_93 is online! » April 20th 2019, 8:08pm
You have 2 wrong.
96-01 SCPI
02-05 MFI
I have an '02 Astro (early) and an '02 Safari (late) in my yard. Both are VIN X, MFI.
Postby 90safari » April 20th 2019, 9:42pm
Yes, you could use a 4.3 from a Bravada, or Jimmy, or Sonoma, or S-10 too. Ideally since you have AWD, I'd get a complete engine that is set up as a 4wd motor. This would save you from having to change the oil pan and possibly the oil pick up tube. However, plan on changing the oil dip stick and maybe the valve covers to allow for oil fill.
My 88 2wd Astro currently has a 92 S-15 Sonoma 4.3 engine in it. Fit like it was made for it too. 8-)
867378671386681
90safari
Blue Status (L2)
Blue Status (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Postby HootenWeb [OP] » April 21st 2019, 2:22am
Thanks for the info.
~Webster
HootenWeb
Postby markmitch » April 21st 2019, 3:17am
I could not find my info on my hard drive I m not quitting but here is some info off the net:
http://www.novak-adapt.com/knowledge/en ... l-block-v6
Topics: 608
Images: 20
Extra Info: RS V8
Postby HootenWeb [OP] » April 21st 2019, 1:14pm
Thanks MarkMitch.
There is a 2003 motor for sale here with 82k on it out of a 2WD S10 for $350
As 90Safari mentioned I would need to then collect all of the AWD parts to make the motor work/fit.
LeeAnn as soon as I figure how to edit my post I will correct the info.
~Webster
HootenWeb
Postby Mmusicman » April 21st 2019, 3:45pm
Weird... my 90-92 LU2 TBI crosses to a carbureted V8! :D
Firing on 6 Cylinders (L5)
Topics: 72
Images: 49
Postby dramey » April 21st 2019, 7:40pm
HootenWeb wrote:As 90Safari mentioned I would need to then collect all of the AWD parts to make the motor work/fit.
~Webster
You already have all of the AWD parts on your present engine. Just swap them over.
dramey
Firing on 7 Cylinders (L1)
Topics: 12
Extra Info: AWD Cargo Van
It is currently October 29th 2020, 12:57am
kade225
Comments: 0
Time: 11:27pm
djpigs
Date: Oct 27 '20
Time: 10:01pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
Users browsing this forum: No registered users and 26 guests
