Replace Fuel Spider, 2001 Safari
Postby Tumbleweed28212 [OP] » May 10th 2019, 3:05pm
I dont see this topic specifically, apologies if I missed it. I've looked at a few you tube videos on the process of replacing the spider, but wonder if you've seen a good video, or a good text description (preferrably with drawings) I have a new spider (bought thru Wally Whorl , Ac Delco, made in Canada) for around $250. My mileage has dropped from 17 / 18 mpg around town to 13 or so, so I figure thats the problem (around only 74,000 miles, just driven mainly by wife, some towing for short trips) I'm most concerned about any wierd / hard to disconnect fittings, getting the injectors in the right spot on the manifold, and the fiddly part of getting the plenum removed from under the air cond lines. (also do you know the torque settings for re-tightening bolts and sequence?) Thoughts appreciated. (I'm also going to replace the plugs, rotor, cap etc at around the same time, but will do one operation first, start the van to make sure it's running right, then do the other, so I don't get the situation confused. Any comments on that operation appreciated too. Hoping to get the van in good order for the long delayed cross country trip with Casita travel trailer..
Tumbleweed28212
Years of Membership: Tumbleweed28212 has been a member for 1 full year
Alias (AKA): Tumbleweed
Van Model Year: 2001
Extra Info: SLT Towing package
Re: Replace Fuel Spider, 2001 Safari
Postby AstroWill » May 10th 2019, 4:00pm
I would test it first, even though it's a good upgrade either way.
Lots of threads about it.
Grab the GM Techline eSI(links in sig), it has all the details and more in it.
Images: 471
Postby Leeann_93 » May 10th 2019, 10:19pm
Pics and text starting in the 7th post on this page:
https://www.astrosafari.com/viewtopic.p ... &start=260
Postby Ericglo » May 11th 2019, 12:21am
There are a bunch of threads on the spider.
Watch Scotty's mobile detailing videos on youtube about spider replacement.
I don't have the thread, but a member here wrote up a good tutorial.
Also look at my recent thread for info on the Permatex sealant to use.
Safari IM & Spider replacement instructions Part 1 of 3.pdf
(594.87 KiB) Downloaded 29 times
Safari IM & Spider replacement instructions Part 2 of 3.pdf
(767.79 KiB) Downloaded 29 times
Safari IM & Spider replacement instructions Part 3 of 3.pdf
(814.59 KiB) Downloaded 27 times
2002 GMC Safari
2004 Chevy Astro
Ericglo
Years of Membership: Ericglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full years
Topics: 19
Postby MechBob » May 11th 2019, 1:31am
17-18 around town? New poster? Sorry, I call crap.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Mmusicman » May 11th 2019, 2:36am
Tumbleweed28212 wrote:My mileage has dropped from 17 / 18 mpg around town to 13 or so, so I figure thats the problem..
You make a pretty BIG assumption!
Lots of things can affect gas mileage.
My 2000 spider went over 200K.
Here's my spider replacement story:
https://www.astrosafari.com/viewtopic.php?f=43&t=132762
Topics: 73
Images: 49
Postby Ericglo » May 11th 2019, 2:37am
My mileage was bad before I replaced the spider. I think I was around 14 to 15 around town. Maybe 17 on a highway trip. I hit 17 and a half on the trip back from Atlanta with new spider.
Strangely, I hit 20 mpg on my trip up to Atlanta. Never saw that before.
2002 GMC Safari
2004 Chevy Astro
Ericglo
Topics: 19
Postby Ericglo » May 11th 2019, 3:07pm
I forgot to add that instead of removing the alternator you should remove the alternator bracket with the alternator still attached. It gives you more room to work and doesn't really take much longer to remove than the alternator itself. You have to remove the tensioner though. There are two bolts and a nut on the front. A 10mm bolt holds a wire on the left side of the bracket. The connector and positive wire to the alternator and your done.
Oh and one more link.
http://www.handymanlyness.com/archives/ ... Jimmy.html
2002 GMC Safari
2004 Chevy Astro
Ericglo
Topics: 19
Postby Leeann_93 » May 11th 2019, 3:34pm
I didn't remove either the alternator or the bracket, either on my '02 or on my '05. Completely unnecessary extra work.
Postby Ericglo » May 11th 2019, 4:12pm
I guess you are correct for just the spider.
2002 GMC Safari
2004 Chevy Astro
Ericglo
Topics: 19
It is currently February 25th 2021, 8:24pm
Ken2.7
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
