Looking for a place to start.......
Postby Trendkiller13 [OP] » January 20th 2012, 8:34pm
I have a 88 Astro (with a V6) and when driving it just died, very quick and that was all she wrote. It will crank over very slowly (like the battery is almost dead) and occasionally it will try and run for a few seconds but it shakes back and forth and sounds like crap. I am just not sure where I should start looking for the problem. Thank for any ideas.
Also I just found this forum and there is a ton on info on here!
Dan
Trendkiller13
Years of Membership: Trendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full yearsTrendkiller13 has been a member for 8 full years
Van Model Year: 1988
Re: Looking for a place to start.......
Postby uknoLSXtro » January 20th 2012, 11:05pm
Welcome to astrosafari
Just a few low cost or free things to check.
Get the battery checked
new Cap & rotar
Ohm out your plug wires
new spark plugs
Compression test or leakdown test
Change the oil (check for gas in the oil)
Clean the carb
Post a video of you trying to start it. Also has it been blowing black or white smoke out the back?
Obedient workers, just smart enough to run the machines, do the paperwork. Just dumb enough to passively accept the increasingly **** jobs and lower pay, the longer hours, reduced benefits, end of overtime, etc. -Paraphrased -George Carlin
uknoLSXtro
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: uknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full yearsuknoLSXtro has been a member for 9 full years
Images: 14
Alias (AKA): uknomeprk
Extra Info: 5.3 lm7
Postby 97cargocrawler » January 20th 2012, 11:57pm
Do you hear the fuel pump kick on before you start it? A sort of whining sound coming from middle rear of the floor....
If not, then maybe it's your fuel pump.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Trendkiller13 [OP] » January 21st 2012, 12:38am
Picked up some stuff, like cap, rotor and plugs/wires. Working on the install on that now. When it tries to run it is like the timing is way out of whack, so I do not think it is the fuel pump.
Thanks for the replies!
Dan
Trendkiller13
Postby ZiLLa » February 19th 2012, 11:18pm
Crank sensor is my bet......
How to Test the Crank Sensor
GM 4.3L, 5.0L, 5.7L
-Part I-
Enlarge
This article will help you to troubleshoot and diagnose a BAD Crankshaft Position Sensor on your 4.3L, 5.0L and 5.7L Vortec equipped GM Pick Up or SUV.
Since the 3-wire Crankshaft Position (CKP) Sensor can not be tested by a Multimeter resistance test (Ohms), I’ve written this article to show you how to do it with just a Multimeter in Volts DC mode. This is a very accurate and effective test and will help you to know if it’s good or BAD.
Since this Crankshaft Position Sensor Test article covers quite a few GM Years, Makes and Models, take a look at the ‘Applies To:’ box on the right and scroll with the ‘Next > >’ button to see all of the applications. Also, the info in this article is geared towards diagnosing and troubleshooting a Cranks but Does Not Start Condition - No Start No Spark Condition.
Here are the contents of this article at a quick glance:
Imortant Suggestions.
Symptoms of a BAD CKP Sensor.
How the Crank (CKP) Sensor Works
CKP TEST 1: Crank Signal Test.
CKP TEST 2: Power Circuit.
CKP TEST 3: Ground Circuit.
Related Test Articles.
Important Suggestions
Suggestion 1: The Crank Sensor test I'm gonna' show you in this article, is one of the most accurate ways to test the Crank Sensor without an oscilloscope (and using only a Multimeter) only if you turn the Engine by hand. You'll need to use a 1/2 Ratchet Wrench and the appropriate socket to turn the Crankshaft Pulley.
Suggestion 2: It's very important that the Spider's Fuel Injector's connector be disconnected while performing the Crankshaft Position Sensor test. Unplugging this connector will disable the Computer from injecting Fuel into the Engine.
Tools Needed to Test the Crank Sensor Sensor
You don't need any expensive tools to test the Crank Sensor on your 4.3L, 5.0L, 5.7L Engine.
Tools You’ll Need:
Multimeter.
You can use a Digital Multimeter or an Analog Multimeter although the Digital one is the preferred one.
If you don't have a Multimeter or need to upgrade yours, check out my recommendation here: Abe's Multimeter Recommendation (at: easyautodiagnostics.com).
1/2 inch Ratchet Wrench
Socket that will fit Crankshaft Pulley Bolt.
A helper.
Symptoms of a BAD Crankshaft Position Sensor
The most common symptom of a BAD Crank Sensor is a ‘Cranks but Does Not Start Condition’. In other words, your GM vehicle will Crank over when you turn the key to the Start Position but will not Start. Below is a simple list of more specific symptoms that accompany a BAD Crank Sensor:
The Ignition System will not produce Spark:
The Ignition Coil will not Spark.
No Spark from all of the Spark Plug Wires.
The Ignition Control Module will not receive a Triggering Signal and without this Triggering Signal, the Module will not Switch the Ignition Coil ON and OFF to produce Spark.
The PCM (Powertrain Control Module=Fuel Injection Computer) will not pulse the Fuel Injectors.
The PCM will not activate the Fuel Pump after the initial priming voltage that the PCM sends to it when you turn the Key to the On position and then to the Start Position.
The PCM will usually NOT set a specific BAD Crankshaft Position Sensor Diagnostic Trouble Code (DTC) when the Crank Sensor goes rogue (goes bad). But, every now and then it does, and when it does you’ll get:
P0336 CKP Sensor Circuit Performance.
P0337 CKP Sensor Circuit Low Frequency Code.
P0338 CKP Sensor Circuit High Frequency Code.
P0339 CKP Sensor Circuit Intermittent.
The most important thing to remember, is that if you get Spark from any Spark Plug Wire, the Crank Sensor is working and the test in this article won't help you.
1
2
3
4
ZiLLa
Years of Membership: ZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full years
Topics: 5
Images: 21
Alias (AKA): Tee
Extra Info: Astro 4.3 AWD
Postby Phantom » February 20th 2012, 12:15am
ZiLLa wrote:Crank sensor is my bet......
GM 4.3L, 5.0L, 5.7L
-Part I-
Enlarge
Tools You’ll Need:
Multimeter.
A helper.
Good info ....but a 1988 astro does not have a crank sensor,, that feature started in 96 :)
Phantom
Firing on 7 Cylinders (L4)
Postby Phantom » February 20th 2012, 12:18am
Trendkiller13 wrote:Picked up some stuff, like cap, rotor and plugs/wires. Working on the install on that now. When it tries to run it is like the timing is way out of whack, so I do not think it is the fuel pump.
Dan
Check the fuel pressure it should be 9-14 psi if you have a TBI ,, if carb it will be close a little less
Check your spark a bad coil can do that
Phantom
Postby astrofixitist » February 20th 2012, 7:10am
No crank position sensor but I had an "89 do that on me and if I remember correctly, there was a Hall Effect switch mounted near the distributor, or under the dist cap that went bad. This item sends engine rpm info to the ECM and would cause symptoms you are describing since it would be in a default signal mode . Mine went without warning in a parking lot and wouldn't even start. Should be easy to get to ,Haynes/others give a couple of quick checks with a voltmeter to confirm.
astrofixitist
Years of Membership: astrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full yearsastrofixitist has been a member for 11 full years
Extra Info: 4.3L RWD 338K miles
Postby ZiLLa » February 21st 2012, 8:08am
Have you had a load test done on the batt?????Always start simple,you would be amazed at what a bad battery connect can do to a OBD1 & OBD 2 sytem,more electronics = more draw,if the batt can't keep up=your stuck.Have the battery checked & check all connects,always start simple & work from there.
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
It is currently December 1st 2020, 4:15pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Today
Time: 12:16am
djpigsdjpigs is online!
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
