Oil leak help
Oil leak help
Postby loganlexow [OP] » May 17th 2019, 5:51pm
Alright, I feel like this is going to be a stupid question, but I have to ask. I've been a motorcycle mechanic for years, and I've done all my own car maintenance. I'm competent with a wrench in my hand. Admittedly, I've never done an intake manifold on an American V style engine. So, when I did the deed on my Smashtro van (actually a Safari), imagine my surprise when it sprays oil from the top and rear of the engine after doing the manifold, oil pan gaskets, valve covers, spider injector. The pan is sealed very well. I used the good Fel-Pro intake gaskets. I used a quality gasket sealer on the pertinent areas. I cannot for the life of me find exactly where it sprays oil. And it seems to be when it's hot and higher-than-idle RPM's. Has anyone run into this? Can anyone point me in a direction to look? I need and miss my van. Attached are pics from the top rear of the engine. And the bottom rear. It's hard to tell in the bottom engine pic, but the oil is streaming down over the starter housing. From the top it's hard to tell because I wasn't able to clean that area of the gunk buildup, but there's a little bit of fresh oil. Once, or if the corner of my eye, I thought I saw a bubble come from the rear of the manifold. However, when focused on the area I never saw it again, so I'm thinking it was a trick of the flashlight. The van had been down for over 6 weeks now between time, money, and shipping. Dear gawd, someone help lol. I also posted this on a Facebook group just in case someone sees a duplicate request for help.
1998 GMC Safari AWD lifted who knows how high on 255/75R17 named Brutus
1999 KTM LC4 640 Enduro
1993 Suzuki Bandit 400
loganlexow
Years of Membership: loganlexow has been a member for 3 full yearsloganlexow has been a member for 3 full yearsloganlexow has been a member for 3 full years
Images: 13
  • Small oil leak near drain plug
    by Eddy » December 11th 2020, 11:25pm in Engines
    Last post by Eddy View the latest post
    December 11th 2020, 11:54pm
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    9
    32
    March 9th 2021, 1:59am
Re: Oil leak help
Postby Captn.Crunch » May 17th 2019, 7:02pm
Sorry to hear of your troubles. Nothing worse than doing all that work only to find out you’re not done. Making sure gaskets don’t shift as you reassemble is important obviously. Valve cover gaskets were always the worst for me. Sorry to say you are looking at taking things back apart and finding what slipped. Run it with the doghouse engine cover off. If it’s the valve covers of the rear seal on the intake you should be able to spot it. Airflow from the fan can make spotting a leak on the front of the engine tough as it blows the oil towards the rear. Make sure the gasket surfaces of the valve covers are flat and not distorted from being over torqued.
99 GMC Safari SLE AWD
2" body lift
S-10 rear leafs
NP236 tc
Detroit Truetrac Torsen rear diff w/3.73's
MFactory Torsen equipped front diff-iron
Soon:
Skid plates
rock rails
Captn.Crunch
Years of Membership: Captn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full yearsCaptn.Crunch has been a member for 7 full years
Topics: 21
Images: 4
Extra Info: 4x4 TwinTorsen diffs
Re: Oil leak help
Postby loganlexow [OP] » May 17th 2019, 7:18pm
Captn.Crunch wrote:Sorry to hear of your troubles. Nothing worse than doing all that work only to find out you’re not done. Making sure gaskets don’t shift as you reassemble is important obviously. Valve cover gaskets were always the worst for me. Sorry to say you are looking at taking things back apart and finding what slipped. Run it with the doghouse engine cover off. If it’s the valve covers of the rear seal on the intake you should be able to spot it. Airflow from the fan can make spotting a leak on the front of the engine tough as it blows the oil towards the rear. Make sure the gasket surfaces of the valve covers are flat and not distorted from being over torqued.
Thank you for your response. I have the doghouse of and ran it. There's no fresh oil from the front of the valve covers. I've looked for pinched and shifted gaskets but can't see anything. The one thought I have is at the rear of the intake manifold I used a different type of sealant that the black goop. I laid a good bit of sealant on both the block and manifold after cleaning both surfaces. Maybe it needs a thicker layer? I'm used to tighter tolerances.
loganlexow
Images: 13
Re: Oil leak help
Postby Captn.Crunch » May 17th 2019, 8:59pm
You can warm up the engine and re-torque everything. Maybe you’ll get lucky
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: Oil leak help
Postby loganlexow [OP] » May 17th 2019, 9:17pm
Well, that's an option I didn't think of! I will see if I get lucky re-torquing things. If this doesn't work, what's the groups consensus on reusing the new bolts that I already used? I am thinking I will just buy a new intake gasket, but the bolts were new when I put them in. Should I buy another new bolt set or can I get away with reusing the bolts since they are new?
loganlexow
Images: 13
Re: Oil leak help
Postby chevymaher » May 17th 2019, 9:45pm
The part in the middle that only has ultra black sealer and no gasket. If you drove it without letting it cure 2 days when you put it together. That is where it is leaking.
Clean it real good with brake cleaner. Paint it on with a Popsicle stick thick. let it sit 3 days. It wont leak.
Re: Oil leak help
Postby loganlexow [OP] » May 17th 2019, 9:49pm
chevymaher wrote:The part in the middle that only has ultra black sealer and no gasket. If you drove it without letting it cure 2 days when you put it together. That is where it is leaking.
And this is the part that I have been wondering about. I put it on thicker than I would normally, but not as thick as you are saying. I did let it cure for a few days though. I am starting to see a redo in my future.......... :banghead:
loganlexow
Images: 13
Re: Oil leak help
Postby chevymaher » May 17th 2019, 9:51pm
yep intake slides around going on and instant not sealing.
Re: Oil leak help
Postby MechBob » May 17th 2019, 10:18pm
If it is rear bottom of intake,you can spray off with brake cleaner,cut it back a bit with razor blade,and put a bead of sealer there. Has been done many times before. Cleanliness and top quality sealer is the key.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Oil leak help
Postby loganlexow [OP] » May 17th 2019, 11:24pm
Alright, I ordered another gasket set. It won't be here until Monday, and I have to work all week. I'll update this thread when I get it back together.
I really need to say THANK YOU to all who chimed in to help a lurker. I miss my van. He's become part of the family.
loganlexow
Images: 13
Re: Oil leak help
Postby Bossman » May 17th 2019, 11:29pm
You mentioned that it 'sprays' oil. Does it actually squirt out of there?
If so I would look at the oil pressure sender. It sits next to the rear of the intake, to the left side of the distributor.
The sender and it's fittings have been known to leak.
Mike
Bossman
Years of Membership: Bossman has been a member for 2 full yearsBossman has been a member for 2 full years
Extra Info: RWD Cargo
Re: Oil leak help
Postby MechBob » May 17th 2019, 11:31pm
If you have doubts about where the leak is,(being a mechanic,I am a believer in verifying the problem, not throwing parts at it), you usually can buy some UV oil dye, and a cheap UV "blacklight" and do some testing.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Oil leak help
Postby loganlexow [OP] » May 17th 2019, 11:38pm
I'm not a fan of throwing parts at it either. However, the probability of it being the intake vs some other item that I didn't touch is too high. It's not leaking from any of the other items I touched/replaced. In the plus side, I'll have time to clean up the area and test again. If it turns out to be something else, I can either keep the gaskets as spares or return them. No big deal
loganlexow
Images: 13
Re: Oil leak help
Postby Astrofarian » May 18th 2019, 2:32am
loganlexow wrote:……………………………
You're only a "lurker" until you start posting. Then, you're one of US!
I would also take a close look at the distributor gasket and body.....
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: Oil leak help
Postby Captn.Crunch » May 18th 2019, 3:14am
loganlexow wrote:Well, that's an option I didn't think of! I will see if I get lucky re-torquing things. If this doesn't work, what's the groups consensus on reusing the new bolts that I already used? I am thinking I will just buy a new intake gasket, but the bolts were new when I put them in. Should I buy another new bolt set or can I get away with reusing the bolts since they are new?
You can re-use bolts. New bolts will stretch and need to re-torqued after the engine has gone through a couple of heat cycles
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: Oil leak help
Postby loganlexow [OP] » May 18th 2019, 3:25am
Well, that's good because I only bought the gaskets. I figure they are brand new with only two heat cycles on them. No worries.
loganlexow
Images: 13
Re: Oil leak help
Postby MechBob » May 18th 2019, 4:47am
"You can re-use bolts. New bolts will stretch and need to re-torqued after the engine has gone through a couple of heat cycles" You and I agree on most things,but her i disagree.If TTS bolts were the "cats meow",All vehicles would be required to return to the dealership,for disassembly and re torque.Stretch bolts came about partiality to compensate the aluminum head movement,on cast iron blocks, back in the 1970's.Then,they progressed it forwards,for piston rod connection bolts, and into crankshaft bolts.Do they promote longer engine life? We probably shall never know.I was a big fan of this technology,for some years,until never saw actual results.Allowing the aluminum cylinder head flex/move across the cast iron block did not improve life expectancy.TTY stretch bolts on the connecting rods have not proved useful,Looks good on paper,but fails in the real world.Cast iron block,use solid fasteners.Aluminum to aluminum,different story.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Oil leak help
Postby gengomepyle » July 3rd 2019, 4:23pm
well if you are talking about the big black plenum thing in the middle, it does have a rubber seal. I just had to replace the lower intake gasket on my 03 and I also replaced the plenum seal.
2003 Cargo Astro Van
gengomepyle
Years of Membership: gengomepyle has been a member for 3 full yearsgengomepyle has been a member for 3 full yearsgengomepyle has been a member for 3 full years
Topics: 10
Alias (AKA): gomer
Extra Info: 4.3
Re: Oil leak help
Postby gengomepyle » July 3rd 2019, 4:26pm
make sure your oil sending switch isn't leaking. that's the long black thing under the distributor. mine was leaking when I bought the van. very easy fix if that is what is causing it.
gengomepyle
Topics: 10
Alias (AKA): gomer
Extra Info: 4.3
Re: Oil leak help
Postby Leeann_93 » July 4th 2019, 5:11pm
gengomepyle wrote:well if you are talking about the big black plenum thing in the middle, it does have a rubber seal. I just had to replace the lower intake gasket on my 03 and I also replaced the plenum seal.
They were not talking about the plenum cover. They are talking about the middle bit under the intake manifold where the gaskets don't cover. That's where the RTV goes.
It is currently March 9th 2021, 1:59am
OldSchoolNoe
Comments: 25
Date: Mar 07 '21
Time: 7:10pm
AppaTheAirBison
Date: Mar 06 '21
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
OldSchoolNoe
Comments: 25
Date: Mar 01 '21
Time: 12:53am
Users browsing this forum: No registered users and 22 guests
