Motor Dip Stick Routing
Postby Slime [OP] » July 15th 2019, 11:35pm
So, how exactly is the dip stick supposed to route? I have the 4.3 on an engine stand. Took the manifold off, but it seems to want to go right in the way of the #4 plug and against the manifold. Also, does it bolt to the manifold mounting bolts?
Slime
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Slime has been a member for 2 full yearsSlime has been a member for 2 full years
Topics: 9
Images: 7
Alias (AKA): slime
Extra Info: Custom Cargo
  • Standard Motor Products vs. AC Delco?
    by gman » March 29th 2020, 11:34pm in Engines
    March 30th 2020, 5:30pm
  • AWD Motor Mounts question
    by jaack » July 28th 2020, 6:03am in Engines
    Last post by jaack View the latest post
    July 29th 2020, 10:19pm
    9
    100
    August 13th 2020, 12:13pm
Re: Motor Dip Stick Routing
Postby CopperFiremist » July 16th 2019, 12:10am
That is correct. I would check and make sure you can get a spark plug socket on it before you tighten it down, #4 can be a real PITA to replace with that tube in the way. I sometimes tweak the tube a bit.
Pullin The Pass
CopperFiremist
Blue Status (L2)
Blue Status (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Slime [OP] » July 16th 2019, 8:40pm
CopperFiremist wrote:That is correct. I would check and make sure you can get a spark plug socket on it before you tighten it down, #4 can be a real PITA to replace with that tube in the way. I sometimes tweak the tube a bit.
Wow...Thanks...I don't remember it being in the way like that, but it has been over 20 years since we took it apart. So, does the one bolt to the stud and the other to that smaller hole above the manifold?
Slime
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Images: 7
Alias (AKA): slime
It is currently August 13th 2020, 12:13pm
pmou
Comments: 43
Date: Jul 30 '20
Time: 3:31am
pmou
Comments: 43
Date: Jul 29 '20
Time: 11:58pm
Attached by: tonydobbs
tonydobbs
Date: Jul 29 '20
Time: 5:41pm
pmou
Comments: 43
Date: Jul 21 '20
Time: 7:13pm
pmou
Comments: 43
Date: Jul 20 '20
Time: 11:50pm
Users browsing this forum: Yandex [Bot] and 5 guests
cron
