Check engine light
Check engine light
Postby Wurmpool [OP] » August 6th 2019, 3:05am
Its a 94 astro. use to drive it about an hour back and forth to work. When the van gets good and hot. If you turn it off. When you turn it back on. For some reason the check engine light comes on. And it idles funny. Still runs and everything just fine. But it only does it when it’s good and hot. If you turn it off and leave it sitting a while. Turn it back on and it runs perfectly. Any ideas what would cause this?
Wurmpool
Years of Membership: Wurmpool has been a member for 1 full year
Alias (AKA): Kozak
  • Repair or swap my engine?
    by G-MO218 » March 28th 2020, 7:44pm in Engines
    March 29th 2020, 6:18pm
  • Wet oil on passengers side of the engine drivers side dry!
    by rjs165 » April 18th 2020, 9:53pm in Engines
    Last post by BirdshakeBirdshake is online! View the latest post
    April 18th 2020, 11:31pm
    99
    September 21st 2020, 3:49am
Re: Check engine light
Postby Sailing_Faith » August 6th 2019, 7:12am
Wurmpool wrote:Its a 94 astro. use to drive it about an hour back and forth to work. When the van gets good and hot. If you turn it off. When you turn it back on. For some reason the check engine light comes on. And it idles funny. Still runs and everything just fine. But it only does it when it’s good and hot. If you turn it off and leave it sitting a while. Turn it back on and it runs perfectly. Any ideas what would cause this?
Post says 94 Astro, your profile says 97.... either way you are going to have to read the code and post it before anyone can help. If it is a 94, you have OBD1 and need to search for the procedure here to read the codes (simple, paper clip and a scrap of paper) if it is a 97, that is OBD2 and you will have to either buy a code reader, or go to your local auto parts store and ask them to read it for you.
Good luck.
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby Wurmpool [OP] » August 6th 2019, 11:40am
I'm looking at a 94 that's for sale
Wurmpool
Alias (AKA): Kozak
Postby chevymaher » August 6th 2019, 11:50am
Check the fuel pump relay.
It is currently September 21st 2020, 3:49am
Maddog
Comments: 31
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:47pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:43pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:40pm
erikw9
Comments: 37
Date: Sep 14 '20
Time: 7:30pm
Users browsing this forum: No registered users and 26 guests
