Super Clean 96 with 112k miles has a knock/ping/tick
Re: Super Clean 96 with 112k miles has a knock/ping/tick
Postby Astro Pop » September 4th 2019, 8:09pm
Is it me or did it sound louder when the camera was under the chassis? That would worry me. I stand by original comment, assume the worst.
Astro Pop
Years of Membership: Astro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full years
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
  • Knock sensor location
    by Dbleeger » December 8th 2020, 11:46pm in Engines
    December 9th 2020, 12:13am
  • 332k+ miles! Maintenance and Preservation?
    by Captain90s » April 11th 2021, 7:10pm in Engines
    April 11th 2021, 10:38pm
    77
    April 15th 2021, 6:51pm
Postby Mmusicman » September 4th 2019, 8:33pm
It's an awful loud "lifter tick" (in my opinion)... but maybe?
Trying to determine on a video can certainly sound a little different than in reality.
Sometimes a really good deal can be had with a lifter tick!
On the other hand.. I once had a lifter tick that turned out to be a wiped-out lifter and cam.
20 years later I still haven't freshened up that engine yet... it still sits on a stand.
It sounds more like a tick, and less like a knock to me.. which "could" be a good thing.
But like I said.. my tick turned into a knock.. which was a bad thing.
Turn out my tick was a bad wrist pin... the engine is history now.
It did seem almost as loud above the engine as below (at least on video)
This could be a good thing.
Not sure how a cracked flexplate sounds in front of engine.
It's also usually helpful to rev the engine to see how the tick/knock reacts...
as well as see how it sounds under load.
My experience.. bearings are usually less likely to knock under certain load, a lifter won't know the difference.
But a bearing knock will change with load and rpm regardless... there's no mistaking it!
Rev it.. see if the tick changes.. which would more likely be a bad thing.
Except for cracked flexplate.. which would be a good thing. lol
Exhaust leaks on the other hand tick during load (or while accelerating), but not while coasting.
You could slip off the belt to be sure it's not an accy.. one of the first easy things I usually do.
A stethoscope might help point you toward the problem such as a valve-train issue.. if the culprit.
If I owned the van and I ruled these out.. then my next step I'd probably disconnect the torque-converter to listen and see if it's the flexplate (common failure too). But it seems maybe a little too loud on top for this?
Topics: 73
Images: 59
Postby JKlug81 [OP] » September 4th 2019, 11:25pm
Mmusicman wrote:It's also usually helpful to rev the engine to see how the tick/knock reacts...
When you rev the engine, the tick speed up with the RPMs. When driving it, they accelerate when the engine winds up, and then slow down as the engine does.
I made an offer of $500. The seller wasn't impressed, I told him to work with me and counter.... waiting for a counter offer. I think my max on this one would be 1k. The full asking price is $2250
JKlug81
Years of Membership: JKlug81 has been a member for 2 full yearsJKlug81 has been a member for 2 full years
Alias (AKA): Josh K
Postby AstroWill » September 4th 2019, 11:52pm
JKlug81 wrote:I made an offer of $500. The seller wasn't impressed, I told him to work with me and counter.... waiting for a counter offer. I think my max on this one would be 1k. The full asking price is $2250
Without engine issues it's worth $2250
Images: 473
Postby JKlug81 [OP] » September 5th 2019, 2:15am
AstroWill wrote:Without engine issues it's worth $2250
Agreed.
What would you offer for this van with its current issue?
It also needs tires, an alignment and a new cat.
I'm looking at an equally clean 02 Safari AWD with 200k miles. It runs as good as it looks. They are asking $2800.
JKlug81
Alias (AKA): Josh K
Postby AstroWill » September 5th 2019, 2:29am
Agreed.
Personally I would be looking at $5-700, unless I already had a cheap engine lined up for it. Also I would be doing all my own work.
It's at a shop, if they thought they could fix it and turn a profit, they would fix it instead of trying to sell it as it sits.
I would be more interested in the 02 as it's a running vehicle, has some decent improvements over the 96, and it's running. But condition overall is something you have to look at. Also, asking price doesn't always = the price you pay ;)
Here is a quick rundown of things that have changed over the years: https://sites.google.com/site/astrosafa ... enerations
Images: 473
Postby JKlug81 [OP] » September 5th 2019, 3:02am
AstroWill wrote:I would be more interested in the 02 as it's a running vehicle, has some decent improvements over the 96, and it's running.
Im actually trying to get both vans..... :mrgreen:
As far as a replacement engine is concerned, I still have the carcass of my 97 that burned back in December sitting in the driveway. Its engine was running beautifully when it died.
JKlug81
Alias (AKA): Josh K
Postby Sailing_Faith » September 5th 2019, 4:10am
:banana: sweet!
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby AstroWill » September 5th 2019, 5:25am
JKlug81 wrote:As far as a replacement engine is concerned, I still have the carcass of my 97 that burned back in December sitting in the driveway. Its engine was running beautifully when it died.
Yep, that definitely makes it an easier purchase.
Images: 473
Previous
It is currently April 15th 2021, 6:51pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: SparkydogSparkydog is online! and 18 guests
