2000 4.3L v6 pulling and swaping motor
Postby jdmpanda757 [OP] » February 5th 2012, 12:24am
Well i know for a fact my motor is seized and now its time to pull it and put a new one in........ can anyone give me some tips on how to does this or help me find a write up anything will help
Thanks
Also I will probly take pics and make notes threw out this whole project so it can help others in the future :D
jdmpanda757
Years of Membership: jdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full yearsjdmpanda757 has been a member for 9 full years
Alias (AKA): adam
Extra Info: 4.3 v6 rwd
Re: 2000 4.3L v6 pulling and swaping motor
Postby Mr_Bowtie » February 5th 2012, 12:35am
If the motor is seized you will have to either pull the tranny with it or pull the torque convertor off with the motor. The motor will be easier to pull with the more stuff you pull off it before trying to remove it.
2 ways to remove the motor......
Cut the front radiator support:
viewtopic.php?f=43&t=4434
OR
Drop the subframe:
viewtopic.php?f=43&t=5936&start=0
Have you ever pulled a motor out before? Cause doing a motor swap in these Vans is a little more challenging.
:chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby jdmpanda757 [OP] » February 5th 2012, 12:54am
[quote="Mr_Bowtie"]If the motor is seized you will have to either pull the tranny with it or pull the torque convertor off with the motor. The motor will be easier to pull with the more stuff you pull off it before trying to remove it.
OR
Drop the subframe:
Yeah I plan on pull in the tranny with it and I've only done swaps on Honda so I know this is gonna be a crzy challenge but I'm up for it and thanks for the links
jdmpanda757
Alias (AKA): adam
Postby Mr_Bowtie » February 5th 2012, 1:10am
The shorter the engine hoist you have the better off you will be trying to get back in there cause with a big hoist its a pain in the azz. Leaving almost everything off the motor that you can really helps too sliding it in and out. We just did a swap on my buddy's '99 Safari....was a pain, but its worth the hassle. We just pulled the torque convertor off with the motor cause his was seized too. Just slide it forward until the torque convertor comes off, making sure not to hurt the input shaft of the tranny. Easier then pulling the tranny.
You can get a 4.3L out of fullsize pickup trucks too....just gotta swap over some parts. :rockon:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby jdmpanda757 [OP] » February 5th 2012, 3:30am
Mr_Bowtie wrote:The shorter the engine hoist you have the better off you will be trying to get back in there cause with a big hoist its a pain in the azz. Leaving almost everything off the motor that you can really helps too sliding it in and out. We just did a swap on my buddy's '99 Safari....was a pain, but its worth the hassle. We just pulled the torque convertor off with the motor cause his was seized too. Just slide it forward until the torque convertor comes off, making sure not to hurt the input shaft of the tranny. Easier then pulling the tranny.
Thanks for the info did you take it out of the front or did you go the sub frame way?
jdmpanda757
Alias (AKA): adam
Postby Mr_Bowtie » February 5th 2012, 4:01am
We took it out the front. It wasn't too bad. :D
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby jdmpanda757 [OP] » February 5th 2012, 4:12am
Mr_Bowtie wrote:We took it out the front. It wasn't too bad. :D
i havent looked for myself just yet but from what ive read people are saying that i have to cut the front support because its a newer year? (2000) is that true?
jdmpanda757
Alias (AKA): adam
Postby Big_kid » February 5th 2012, 4:14am
Got a donor engine yet? If not, Pick N Pull should have something out there in the $200 range.
http://www.picknpull.com
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby jdmpanda757 [OP] » February 5th 2012, 4:16am
Big_kid wrote:Got a donor engine yet? If not, Pick N Pull should have something out there in the $200 range.
thank you i will most deff. check then out considering theres one not to far from me! :D
jdmpanda757
Alias (AKA): adam
Postby Big_kid » February 5th 2012, 4:23am
$179.99 plus $49.99 core charge. If you find something that was wrecked, odds are it was running when it hit whatever it hit. I just looked, they have an '02 Astro listed in inventory.
You could also check Craigslist, I stay out of the cars & trucks section. Too much temptation in there for me.
Topics: 185
Images: 344
Postby jdmpanda757 [OP] » February 5th 2012, 4:29am
Big_kid wrote:$179.99 plus $49.99 core charge. If you find something that was wrecked, odds are it was running when it hit whatever it hit. I just looked, they have an '02 Astro listed in inventory.
yeah i seen the '02 and i know the temptation your talking about lol if i had money i would be just as broke as i am now but with alot of cheap cars and parts lol
jdmpanda757
Alias (AKA): adam
Postby Big_kid » February 5th 2012, 4:38am
I've not looked, but I wonder if it's feasible to put a crank kit in one of these vans without pulling the motor? I've done it in an Olds station wagon & an E150 van.
Topics: 185
Images: 344
Postby jdmpanda757 [OP] » February 5th 2012, 4:43am
Big_kid wrote:I've not looked, but I wonder if it's feasible to put a crank kit in one of these vans without pulling the motor? I've done it in an Olds station wagon & an E150 van.
i wouldnt know lol
jdmpanda757
Alias (AKA): adam
Postby chevymaherchevymaher is online! » February 5th 2012, 5:24am
I had my bottom end apart doing the oil pump spring.On a RWD I think it could be done.Plenty of room to get the crank out.
Topics: 91
Postby Mr_Bowtie » February 5th 2012, 9:34am
Yes you have to cut the front support........I posted a link in my first post to a thread all about that.
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
It is currently April 14th 2021, 8:49pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: Google [Bot] and 19 guests
