Correct Temperature Thermostat???
Postby BillyJoBob [OP] » October 17th 2019, 9:48pm
Replacing radiator in my 98 Safari 2WD and decided it was a good idea to replace Thermostat while I have it all apart (the part about taking the entire grill and lights off to get to 2 screws is a little silly, doncha think GM?).
My question is, what temperature Thermo is correct for this engine? I see 160 to 198 temp thermos all over Rock and O'Reilly. I searched for this info here before I posted but didn't see my answer. Isn't in the GM Shop Manual either.
I have owned 3 of these 97 or 98 vans and the temp gauge on the dash always reads 195 for the normal operating temperature. That might lead me to believe any 195 thermo or the 198 AC Delco to be the correct one but would rather have someone who knows tell me.
I also have a dim memory of a discussion somewhere about not being able to pass smog in sunny CA if the wrong one is installed.
As always, TIA
BJB
Planned Adolescence
1998 RWD Safari, AC, 170K
RIP - 1998 Astro - wouldn't Smog, now owned by the State of CA
BillyJoBob
Years of Membership: BillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full yearsBillyJoBob has been a member for 9 full years
Topics: 16
Alias (AKA): BillyJoBob
Extra Info: V6 RWD 180k
  • Electric Fan Temperature Probe. Looking for available 3/8"
    by blinkibus » September 12th 2020, 3:14am in Engines
    Last post by Rinny View the latest post
    September 17th 2020, 5:58pm
  • Thermostat
    by DaHonu » September 13th 2020, 8:12pm in Engines
    Last post by augidog View the latest post
    September 17th 2020, 3:26pm
    84
    March 3rd 2021, 4:00pm
Re: Correct Temperature Thermostat???
Postby AstroWill » October 17th 2019, 10:14pm
The ones on RA that state 'OE temperature' and do not state 'Alternate Temp'.
Though the service manual will talk about using temperature sticks of 188f and 206f in the thermostat diagnostics section.
Images: 472
Postby BillyJoBob [OP] » October 17th 2019, 10:32pm
Thanks Will, shore cain't beat the service around here!
Planned Adolescence
BillyJoBob
Topics: 16
Postby AstroWill » October 17th 2019, 10:37pm
You are most welcome. 18ftlbs for the thermostat housing.
Images: 472
Postby BillyJoBob [OP] » October 17th 2019, 10:45pm
Which leads to a more dire question.
I am having trouble getting at the 1/2" nuts, one of the problems is the bolts stick up too high for a standard socket and deep sockets that will wrap around the nut can't get a driver attached cuz it's too high. I appear to need a particular off set wrench or ??? ... something?
I did one of these 10 years ago but was working at a friends mechanics shop and we both struggled with it and his complement of tools
Any ideas appreciated
Planned Adolescence
BillyJoBob
Topics: 16
Postby Leeann_93 » October 17th 2019, 11:00pm
You've removed the intake air hose at the throttle body?
Now pull the doghouse cover and unscrew the plastic wing nut at the back of the throttle body. Tilt the 'hat' - the adapter from hose to throttle body - forward and pull off. Pull the upper radiator hose from the neck - after draining enough coolant to get it below the level of the thermostat.
Now you have full access to the bolts.
Oh! You'll need a 14mm to pull the nut on the back stud, then pull the ground wire off the stud, then 13mm deep for the stud just like the front.
Postby BillyJoBob [OP] » October 18th 2019, 12:31am
Well LeAnn, thanks, worked like a charm and it's off
Except I see no ground wire on mine. Where should that be going?
Planned Adolescence
BillyJoBob
Topics: 16
Postby Leeann_93 » October 18th 2019, 1:46am
Should come out of the huge bundle in the wire loom and have a single wire to a ring terminal that fits onto the rear stud. You can see it in my pic; click on it to make it big.
Postby AstroWill » October 18th 2019, 2:39pm
Could be that someone/PO relocated it as well. You would surely know if that ground was missing.
Images: 472
Postby BillyJoBob [OP] » October 18th 2019, 3:16pm
I will scout around but have no idea what I would be looking for
What would be the symptoms if it was missing?
Planned Adolescence
BillyJoBob
Topics: 16
Postby AstroWill » October 18th 2019, 3:39pm
If everything is working fine, don't worry about it.
Images: 472
Postby steveweed » October 23rd 2019, 11:22pm
Hey Billiejo I run a 180 in my 95 astro but I live in florida and it works fine but just warm heat in winter but only a few weeks a yr it gets cold here but 195 is stock
steveweed
Years of Membership: steveweed has been a member for 1 full year
Alias (AKA): steve
Extra Info: conversion van
It is currently March 3rd 2021, 4:00pm
Attached by: MHM
MHM
Comments: 22
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
