1994 Astro leaking some kind of gas from corner under hood.
Postby blendergasket [OP] » February 9th 2020, 4:02am
I drove my van about 5 miles just now and my friend commented on a smell. I drove to a gas station and noticed steam coming from the corner of the hood closest to the passenger mirror. The leak appears to be offgassing from the pipes right next to the blower motor.
It's basically done offgassing. What type of gas/fluid did I lose? Can I safely drive 50 miles home without it?
Thank you for the info.
1994 Astro Ext AWD
blendergasket
Years of Membership: blendergasket has been a member for 3 full yearsblendergasket has been a member for 3 full yearsblendergasket has been a member for 3 full years
Topics: 20
Alias (AKA): blendergasket
Re: 1994 Astro leaking some kind of gas from corner under ho
Postby Rod's Trucks » February 9th 2020, 5:04am
There are several heater hose connections which come together at the heater control valve almost directly below that area. If it had a slightly sweet smell, it might have been antifreeze mixture boiling off a hot exhaust manifold.
There re also some A/C hoses in the area, but that would be an unlikely source of steam.
Watch temp gauge and check coolant often until fixed! LET IT COOL, and BE VARY CAREFUL IF ATTEMPTING TO OPEN COOLING SYSTEM WHeEN hot.
Good Luck.
Rod J
Issaquah, WA
Rod's Trucks
Topics: 32
Images: 55
Alias (AKA): Rod and/or WE7X
Postby blendergasket [OP] » February 9th 2020, 6:43am
Thank you for your reply. It sounds like it is the heater core then? I ended up using my AAA and I got it towed to my home so I can try to fix it.
I wouldn't call the smell sweet, sort of a plasticky new shoes type of smell. The gas/liquid was seems to have been blowing forward from somewhere in the corner, but it was hard to tell where from. I will try to find the leak tomorrow night when I get home.
1994 Astro Ext AWD
blendergasket
Topics: 20
Postby AstroWill » February 9th 2020, 3:40pm
Could just be hoses, heater core, control valve, etc. Borrow a pressure tester from your LAPS and use it when COLD to find your leak.
Images: 472
Postby Toskavat » February 9th 2020, 6:19pm
If your coolant level is all right, and it smelled like plastic, check the plug on the blower resistor. Could be blower motor current overdraw roasting the plug. Good luck.
Toskavat
Years of Membership: Toskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full years
Images: 24
Alias (AKA): ASTRORC
Extra Info: 4.3 V6 2WD
Postby blendergasket [OP] » February 9th 2020, 7:00pm
Toskavat wrote:If your coolant level is all right, and it smelled like plastic, check the plug on the blower resistor. Could be blower motor current overdraw roasting the plug. Good luck.
Would that explain the steam that came out? I actually have a blower motor resistor on the way because my blower doesn't work so I will install it as I work on the leak
1994 Astro Ext AWD
blendergasket
Topics: 20
It is currently March 1st 2021, 8:47pm
Attached by: MHM
MHM
Date: Today
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
