Remote start
Remote start
Postby ZiLLa [OP] » February 19th 2012, 5:24am
Need to know wheres its located,& if it can be accessed with my existing key fob,van is new to me & don't need my hands chopped while working on it.(factory option or add on?)
ZiLLa
Years of Membership: ZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full yearsZiLLa has been a member for 8 full years
Topics: 5
Images: 21
Alias (AKA): Tee
Extra Info: Astro 4.3 AWD
  • 2000 astro stalls and now won't start
    by Tonedeft » May 3rd 2020, 2:06am in Engines
    Last post by Tonedeft View the latest post
    May 3rd 2020, 10:28pm
  • 94 Astro no start after fuel pump install
    by grimbeardsly » June 7th 2020, 1:16pm in Engines
    Last post by grimbeardsly View the latest post
    June 21st 2020, 2:18am
    98
    October 28th 2020, 6:47pm
Re: Remote start
Postby Phantom » February 19th 2012, 4:55pm
They are most commonly installed up under the drivers side of dash , but could be behind kick panel ,, it is actually wherever the installer decided to put it , since the astro did not come with a factory remote start it will be an aftermarket setup and most likely not compatible with the factory key fob as it is only for remote keyless entry and not for starting the van , aftermarket systems should have a toggle switch in the same area that disables the remote start for safety reasons
Phantom
Firing on 7 Cylinders (L4)
Re: Remote start
Postby ZiLLa [OP] » February 19th 2012, 6:49pm
Thank you Phantom,No disable switch that I can find,When it quits snowing I'll get a pic of the Warning sticker under the hood,so I guess I'll have to trace down the manufacturer,& see about getting a fob & codes from them,should be a serial # & product code on the unit(if I can find it). :)
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby ZiLLa [OP] » February 19th 2012, 9:34pm
Theres a pic in my album of the sticker now that its quit snowing.Maybe you tell me who the manufacture is????(MAYBE)
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby Phantom » February 19th 2012, 9:41pm
DEI is Directed Electronics Inc..
They are the parent company of many brands of remote start systems of which Viper is one of them ,,, you'll need to locate the main brain box and get numbers off it to know what make and model your unit is
Phantom
Re: Remote start
Postby ZiLLa [OP] » February 19th 2012, 10:28pm
Just found that out,on their site now.....supposedly it has the (works) gonna have to give them the vin so I know what it has & where the BOX is....according to the rep they record all vins & systems.WE'LL SEE......
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby ZiLLa [OP] » February 20th 2012, 3:50am
How big is the box????? Going spelunking tomorrow...they shut me down at 7PM,obviously gonna need the ssn, Guess I'm ripping the dash apart.
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby Phantom » February 20th 2012, 12:28pm
It can vary but usually about 8-9 inches long 4-5 in wide 1-2 in thick and many wires coming out of it
Phantom
Re: Remote start
Postby sfeaver » February 20th 2012, 4:22pm
Normally the brain gets put above where your feet would go on the drivers side. You can also trace from the ignition wires that would go to the key. Thats where the start wires will be spliced in.
Also, there should be a pin switch to sense when the hood is open. Although since they corrode, they tend to get disconnected. If that works though, it shouldnt start with the hood open.
Scott
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Re: Remote start
Postby ZiLLa [OP] » February 21st 2012, 5:50am
Appreciate the replys,& so far DEI....is being no help,got hung up on yesterday for no reason & haven't been able to get through since,they have a help site & so far no replies by e-mail either.I'm off tomorrow & will get under the dash & see whats up.& got 2 more ?'s for Phantom...If it is a Viper system,did they usually incorporate a alarm with it.& my rear cabin stereo quit working today,it will take a cd but no play,& the display shut dwn,time for a new stereo?,or on the sony,is there 2 separate power feeds,already checked the cabin breakers & all is good.Will be pulling that as well,Grand kids don't like using the headphones,& the aux on the stereo runs the TV & VCR sound through its own speaker setup.Not a big deal,fixing to upgrade to flat panels & a DVD anyway,just wanted to get your input.
Thanks,Tee
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby Phantom » February 21st 2012, 7:35am
It depends on the model and how old the remote start system is ,, sometimes they do not have an alarm , most newer systems do come with an alarm these days though ,. On the rear cabin stereo it may have a loose or broken wire feed for power as some systems have more than one power feed ;sometimes a faulty power cable , it may have more than one fuse that feeds to it and may have one blown and it may be wired to front fuse panel under the dash .What model number is it? If you planning to upgrade to flat panels & a DVD , not worth putting money in it
Phantom
Re: Remote start
Postby ZiLLa [OP] » February 21st 2012, 8:18am
Thanks Phantom,pretty sure all the AV runs off the breakers in the back,pick of the sony is in my album,you have any suggestions on where I should have the AV replaced.?...shouldn't be too pricey,as all the wiring is already there.(ABOUT 5 MILES OF IT)LOL
ZiLLa
Topics: 5
Images: 21
Alias (AKA): Tee
Re: Remote start
Postby chevy4life » March 2nd 2012, 1:17pm
I have a 95 2wd w/ bulldog remote start installed 2 years ago by previous owner and it won't work when cold. What can cause this problem besides cheap *** remote start? :?:
chevy4life
Years of Membership: chevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full yearschevy4life has been a member for 8 full years
Alias (AKA): JT
Extra Info: eaton detroit locker
Re: Remote start
Postby chevymaher » March 2nd 2012, 1:43pm
chevy4life wrote:I have a 95 2wd w/ bulldog remote start installed 2 years ago by previous owner and it won't work when cold. What can cause this problem besides cheap *** remote start? :?:
My sister had one for her truck.It will not work for her truck.Warm it starts it and cold it won't. Multiplier target of the remote start locks after 3X,and it must be manually reset.In the fine print of the instructions it says it has this problem on some vehicles.The remote start only cranks the engine 2 seconds.Well her truck takes 4-5 seconds of cranking cold to fire.
Re: Remote start
Postby chevy4life » March 3rd 2012, 3:24pm
No, not starting...nothing, no start, no unlock lights etc. Not about number of cranks it doesn't do anything at all in the cold. Everything else works starting with key just not remotely.
chevy4life
Alias (AKA): JT
It is currently October 28th 2020, 6:47pm
djpigs
Time: 10:01pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
Comments: 61
Date: Oct 09 '20
Time: 2:58am
Users browsing this forum: No registered users and 22 guests
