I would replace the pan. Removing the pan on your 2000 takes less than an hour, and doing that will give you the opportunity to assess the "loud clattering sound" you described. That sounds like a connecting rod bearing (or SIX) has run dry. Only you can decide how to proceed from there, if that's the case. I seriously doubt that simply replacing the pan will cure whatever is now hammering down there. Sorry to be the bearer of bad news....
-M!ke-
If you have a pick n pull junkyard around you can grab the pan off another Astro cheaply, an this also lets you take everything apart on a vehicle which is not yours 1st.
You could drill it out and tap it with a larger hole, and buy a larger sized plug, but swapping the pan will be your safest bet as you cannot mess anything up. I have had to do this with my motorcycle so it is an option, but t would also depend on your pans current stripped condition. Look into "Heli-Coil" to get an idea of this, it is less work up front since you do not have to take all the parts off to get to the oil pan if you were re-threading instead, but does leave room for error/a problem.
Everything Wiley pointed out above is good, useful information^^^. My main thinking, though, is that dropping the pan will give access to the crank & rods for inspection. This is one time I definitely DON'T want to be "right" but I strongly suspect some bearings (or WORSE) got eaten here.
Drop the pan.
Let's hope I'm wrong, but I don't know a better way to know for sure.
Best of luck to you!
-M!ke-
..I noticed my van running extremely rough and loud clattering sound while goin down the road. I peeled off as fast as I could and as I investigated I found no plug in sight, and probably left several quarts of new oil down the past couple miles of freeway. I hope I no serious damage occurred else where.....
You were probably running the engine with NO oil after the first couple blocks.. not miles.
Light should have come on.
I would try a better "temporary" solution first, to see if it still runs
Yup. That's really the only way to know. Put a temp plug in place, top up the oil level, fire it up and listen for expensive noises. ray:
23.1K members
