Fark Me, Shop Put Green Stuff in the Dexcool...
Postby iLikeToAstroSafari [OP] » May 22nd 2020, 2:23pm
Been slacking in my other thread, crazy busy and been meaning to post pics, and will.
Long story short picked up a '98 AWD.
Did not know these vans use dexcool...
Reservoir had fresh bright green stuff in it during inspection.
Seller "serviced" vehicle before sale at a shop.
Please guide me on how to properly flush all this crap out on these vans, hopefully not too much damage was done.
Vehicle towed home, but idled in sellers driveway for 1+ hour (diagnosing gauge/heater).
Put MAYBE 10km on her since.
Orange leak from bottom of van when at home idling for 5 minutes. No leak when in sellers driveway.
Opened rad cap, SURPRISE! Dexcool.
My first step is to remove all the dexcool and flush the coolant passages best I can, yes, even with my leak. I want this devil of a fluid out of the van.
I have ramps, pressure tester, drain pans, access to de-ionized water, and almost every automotive tool known to man, or a doohickey equivelant.
But, all vehicles have their quirks and these vans are new to me. Astro Safarians, please guide me on the best way to get this horrible horrible stuff out.
Plan is to put the good ol' Prestone green stuff in it, unless there is something that works better for the Vortec 4.3s? Dexcool is NOT going back in.
I pray the leak is from a cracked rad or hose, and I am not a praying man.
Please cross your fingers (and toes) for me.
Last edited by iLikeToAstroSafari on May 22nd 2020, 3:57pm, edited 1 time in total.
iLikeToAstroSafari
Extra Info: LT AWD
  • Let's Look at My Spider and Intake Stuff
    by Sparkydog » September 29th 2020, 3:36pm in Engines
    September 30th 2020, 10:52pm
  • My '05 is Dead....(to me).
    by randynavarro » February 8th 2021, 11:45pm in Engines
    Last post by randynavarro View the latest post
    February 10th 2021, 7:47pm
    97
    March 5th 2021, 7:28am
Re: Fark Me, Shop Put Green Stuff in the Dexcool...
Postby markmitch » May 22nd 2020, 2:34pm
dexcool is orange and is junk green stuff is ethylene glycol and is good stuff. drain coolant into bucket then leaving radiator petcock open stick a garden hose into the radiator neck turn the hose on slow start the engine and let it flush. If you think it needs more flush then that then close pet cock get a gallon jug of water dump a bit out then add 1 cup of cascade dish washer powder add to gallon let it sit in the sun to warm up shake it good to mix then dump into radiator. start engine let it run for about an hour let cool then open radiator to flush again do the hose thing again to flush it real good. fill with appropriate fluids, I use 50/50 because it really does not get to freezing here in NorCal. You want the green stuff not the orange stuff.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 21
Extra Info: RS V8 AWD
Postby Wiley » May 22nd 2020, 2:56pm
Also note you may not have a radiator petcock, in that case you just remove the hoses, it's a little messy.
Having the sludge myself, My green/orange issue started 10 years ago, and I took the van on a two year trip after the mixing of coolants, so it is not the end of the world. That said, I would even go a step further from markmitch's suggestion and remove each hose and blast water into every orifice to clean as much out as you can. I personally don't mind using a garden hose to do this, and running distilled water through later, but you may not want to use tap water at all, just my opinion.
Since this probably happened recently, I recommend you get under the van and open the engine block drain plugs. There are two, they are SAE size 9/16, and probably tough to get to, I have a lift, and some parts out so it was easy. When I removed the plugs, NOTHING came out, I had to take a pick in there are open it up so water now flows freely out of them.
The opening of the engine block was last week so maybe it would have been cleared originally if I had opened those and flushed years ago, which is why I suggest getting in there despite the difficulty. To get to the one on the passenger side you most likely have to remove the starter, I believe you can get around the front drive shaft and oil cooler lines when doing the drivers side, but again not sure. Not incredibly difficult but you may end up going down the rabbit hole deeper than you planned.
Engine Block Drain Plug
Passenger side plug removed
Drivers side plug removed
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 7 full yearsWiley has been a member for 7 full yearsWiley has been a member for 7 full yearsWiley has been a member for 7 full yearsWiley has been a member for 7 full yearsWiley has been a member for 7 full yearsWiley has been a member for 7 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Postby MechBob » May 22nd 2020, 3:37pm
Well, as the older "bad" green stuff was eliminated many years ago, and almost all coolant is all models,all makes, and is also OAT, your fears are probably unfounded. The color of it is meaningless, nowadays. Personally, I would never pay the price for dex, I use universal.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Leeann_93 » May 22nd 2020, 3:48pm
All of my vans through '02 have a radiator petcock, but my '05 does not. And it is a factory radiator. Pulling the lower radiator hose speeds emptying both the radiator and block but, as Wiley said, it is a bit messy.
There are block drains as well; pipe plugs on both banks. Pull those and the lower radiator hose. You might need to poke something into the block drain holes to break up the crusty crap to let things drain. Once it stops pouring out, put plain water in the radiator until it runs clear. Pull the upper rad hose and remove the thermostat neck and thermostat, and pour plain water in there until it runs clear out of the block drains.
If it's no longer getting below freezing up there, you can fill with water and drive it around for a week or so, then drain everything again and fill properly with green and distilled water.
If you don't see any signs of sludge or sand on the cap or down the neck, it probably isn't a problem. Most coolants, as Bob mentioned, are now OAT. Just don't get Xerex Gold as that is HOAT and incompatible (it's for Chrysler vehicles - I have it for my Jeep). The original DexCool was a problem, but part of that problem was the plastic gaskets GM used - that version ate plastic. The reformulated DexCool is much improved. I just don't like paying extra for something because of a name.
It is currently March 5th 2021, 7:28am
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
