Upgraded Radiator and Oil and Transmission Cooler Set-Ups
Postby ri$e*above [OP] » June 28th 2020, 2:57pm
I noticed my oil lines are leaking. I was about to change the oil and filter, so figured I'd deal with it all at once. The delete StickerSafari posted sounds like a good solution. But what other options other than replacing the factory lines or the delete did you guys go with? I'm thinking of buying a performance radiator and electric fan, and running a separate oil and transmission coolers from that radiator to avoid any cross contamination issues down the road. Has anyone done that? What set-up did you use? Did you use a oil cooler kit, or just use the OEM oil adapter and just use new lines?
Cheers
CURRENT: 2002 GMC SAFARI AWD SLE 'GOLD DIGGER'. 5 INCH LIFT. G80. GT4.
ri$e*above
Van Model Year: 2002
Extra Info: AWD SLE
  • how to add aux. engine oil cooler
    by DentManDave » June 20th 2020, 6:47pm in Engines
    Last post by 90safari View the latest post
    June 25th 2020, 10:07pm
  • 1st gen radiator replacement
    by jackmcd786 » March 22nd 2020, 2:02am in Engines
    April 6th 2020, 11:43pm
    7
    39
    July 9th 2020, 5:32pm
Re: Upgraded Radiator and Oil and Transmission Cooler Set-Up
Postby SportsBoy » June 28th 2020, 9:55pm
The stock rad already has separate oil and trans cooler lines going to separate coolers within it. Maybe I'm reading this wrong, but seems like you're looking to replace stock with stock?
SportsBoy
Years of Membership: SportsBoy has been a member for 2 full yearsSportsBoy has been a member for 2 full years
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby ri$e*above [OP] » June 29th 2020, 2:01am
SportsBoy wrote:The stock rad already has separate oil and trans cooler lines going to separate coolers within it. Maybe I'm reading this wrong, but seems like you're looking to replace stock with stock?
I've heard of people fixing up their oil lines with a more permanent solution to fix that weak point, but then that shifts the weak point to within the radiator and could cause cross contamination. Looking to buy a new radiator with no lines running through it so I can just run external cooling lines. Seems the lines and coolers get a mixed opinion. I've spoke to guys that have had zero issues at all, but also spoke to guys that have replaced lines multiple times in a year.
ri$e*above
Extra Info: AWD SLE
Postby Wiley » June 29th 2020, 5:49pm
Fixing the leaky lines with high pressure hose and good clamps works well overall, but I had to do it 3 times over the course of a decade, so I finally did the delete.
You can just take the lines out of the old radiator leaving the empty holes, you do not need to plug the holes but you can do so for aesthetic reasons if you chose. If you buy a new radiator, it will come with those holes plugged, so just leave them as is, but nothing will run through that part of the radiator after the delete so you can take it out and drive it today!
You can run an external cooler regardless to if you choose to go with a new or old radiator. For now I do not believe I will add a cooler, but have yet to drive it since the delete.
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Extra Info: AWD 2 inch Lift
Postby Sailing_Faith » June 29th 2020, 6:25pm
The oil cooler is really not needed.
Sailing_Faith
Topics: 56
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby drameydramey is online! » June 29th 2020, 6:52pm
I deleted my oil cooler 4 years ago with no adverse effects.
Firing on 7 Cylinders (L1)
Years of Membership: dramey has been a member for 3 full yearsdramey has been a member for 3 full yearsdramey has been a member for 3 full years
Topics: 12
Extra Info: AWD Cargo Van
Postby N6KB » June 29th 2020, 7:34pm
I'm confused about all of this. Can someone please explain it to me. Is the oil cooler what you are talking about deleting? Does my stock 2005 Astro have an oil cooler? Or is this only something people have added? I think my radiator has water hoses for the normal engine cooling and it also has lines going the the transmission to cool the tranny fluid. Does it also have an oil cooler integrated into it along with the water and tranny fluid cooling?
N6KB
Years of Membership: N6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full years
Topics: 48
Images: 6
Alias (AKA): N6KB
Postby M_a_t_t » June 29th 2020, 10:12pm
N6KB wrote:I'm confused about all of this. Can someone please explain it to me. Is the oil cooler what you are talking about deleting? Does my stock 2005 Astro have an oil cooler? Or is this only something people have added? I think my radiator has water hoses for the normal engine cooling and it also has lines going the the transmission to cool the tranny fluid. Does it also have an oil cooler integrated into it along with the water and tranny fluid cooling?
The oil cooler is built into the radiator. You can't delete the cooler itself. You just remove the lines that connect the engine to the cooler. Then remove the adapter on the block.
How Leeann describes removal of the adapter.
Leeann_93 wrote:⅜" Allen for the adapter. Remove it with the adapter bolted to the block (it can be really tight, so having the adapter securely bolted to the block helps), then use a T-40 to remove both bolts for the adapter. Once that's off, the ⅜" Allen will reinstall the filter mount to the block.
Some more pics from 3M
Mmusicman wrote:If I understand your question.. you have to remove the center threaded portion and move it to the engine block where the cooler adapter was. It uses a hex socket.
M_a_t_t
Topics: 25
Images: 82
Extra Info: cl rwd
Postby ri$e*above [OP] » June 30th 2020, 1:19am
Wiley wrote:Fixing the leaky lines with high pressure hose and good clamps works well overall, but I had to do it 3 times over the course of a decade, so I finally did the delete.
Thanks for the advice.
I'm thinking of just doing the delete and leaving in the factory radiator. Maybe run an external oil cooler with a fan that I can turn on/off in hot weather, and/or when I haul a trailer. I was reading about how using synthetic oil helps a lot with the cooling/wear on the motor too.
Do you have a transmission cooler?
dramey wrote:I deleted my oil cooler 4 years ago with no adverse effects.
Sailing_Faith wrote:The oil cooler is really not needed.
Do you guys live in hot climates, and/or haul a trailer or anything? Just trying to figure if I should maybe run an external cooler with a fan for hot days or when pulling a trailer. Is there any difference in temperatures or oil pressure after the delete? Also, do you use the same viscosity oil as when you were running the oil cooler?
ri$e*above
Extra Info: AWD SLE
Postby ri$e*above [OP] » June 30th 2020, 1:24am
M_a_t_t wrote:The oil cooler is built into the radiator. You can't delete the cooler itself. You just remove the lines that connect the engine to the cooler. Then remove the adapter on the block.
Thanks for the advice,
Did you do the delete also? The delete seems to be the best option from all of the people thatg I'm seeing that have done it with no issues.
ri$e*above
Extra Info: AWD SLE
Postby ri$e*above [OP] » June 30th 2020, 1:38am
Is the transmission cooler also known for having issues like the oil cooler? I have the transmission package and seems like I have an additional huge radiator mounted on the front of the regular radiator.
ri$e*above
Extra Info: AWD SLE
Postby Wiley » June 30th 2020, 8:23am
ri$e*above wrote:Is the transmission cooler also known for having issues like the oil cooler? I have the transmission package and seems like I have an additional huge radiator mounted on the front of the regular radiator.
I added the trans cooler in 2010, easy and recommended. Depending on what you are describing, the cooler will tie into the radiator lines, otherwise you may be confusing it with the giant AC cooler thingy.
This is an example of a transmission cooler that someone added on, you see the outlet and inlet lines will connect to the radiator, this is not an Astro but t is the same idea.
Wiley
Postby SportsBoy » June 30th 2020, 8:57pm
Like the oil cooler, there is a transmission fluid cooler built into the rad - it doesn't cause nearly as many problems as the oil cooler lines do though.
Many people add an external tranny cooler for towing, but you might already have an upgraded tranny cooler with your tow package, which would explain the extra radiator in front of your normal one - unless it's just the a/c condenser you're talking about.
My understanding is that towing puts more strain on the tranny vs the engine in terms of temperature. With your lift, it may be a good idea to switch to an efan since the stock fan may not be lining up with the radiator as it was originally, reducing cooling power.
SportsBoy
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby drameydramey is online! » June 30th 2020, 9:13pm
I live in Alaska and drive in temperatures that range from +95F to -55F. Most of the time the temperatures are from +70F to -35F. I do pull a camping trailer, snowmobile trailer, or a canoe trailer. I deleted the oil cooler and added an auxiliary transmission cooler. I removed the stock cooling fan and replaced it with 2 electric fans.
Topics: 12
Postby M_a_t_t » June 30th 2020, 9:17pm
I did out of necessity for my v8 swap. Then I pulled this thing (not the best decision). I haven't had any issues, but I haven't put many miles on the swap yet either.
98650
M_a_t_t
Topics: 25
Images: 82
Extra Info: cl rwd
Postby ri$e*above [OP] » June 30th 2020, 11:01pm
I'll have a look. The radiator in front of my regular radiator is pretty big, so maybe that's the AC thing. Although with it having the factory transmission package, I'm guessing it has an additional radiator/heat exchange somewhere.
SportsBoy wrote:Like the oil cooler, there is a transmission fluid cooler built into the rad - it doesn't cause nearly as many problems as the oil cooler lines do though.
Are the transmission cooler lines better quality than the leaky oil cooler lines or something, or are the transmission lines just less problematic due to less pressure than the oil cooler?
Yeah, I'm guessing there's an extra radiator/heat exchange somewhere for the transmission...I'll have a good luck for it when this rain stops.
I was actually thinking of going with an electric fan/s. I've never done that before with any of my cars/trucks/vans though, so need to research into doing it.
dramey wrote:I live in Alaska and drive in temperatures that range from +95F to -55F. Most of the time the temperatures are from +70F to -35F. I do pull a camping trailer, snowmobile trailer, or a canoe trailer. I deleted the oil cooler and added an auxiliary transmission cooler. I removed the stock cooling fan and replaced it with 2 electric fans.
Did you keep the factory radiator, and tie in the auxiliary transmission cooler into that loop?
I'm thinking of going with electric fans too. I need to research into doing that, as it will be my first time doing it. Is it pretty straight forward to do?
M_a_t_t wrote: I did out of necessity for my v8 swap. Then I pulled this thing (not the best decision). I haven't had any issues, but I haven't put many miles on the swap yet either.
98650
Wow, that's some weight! Did you damage anything pulling that?
ri$e*above
Extra Info: AWD SLE
Postby SportsBoy » July 1st 2020, 3:27am
they are different - tranny lines are all metal, oil cooler are rubber and metal crimped together.
SportsBoy
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby M_a_t_t » July 1st 2020, 3:31am
I had to change the rear wheel bearings. Just started to make noise when I turned afterward.
M_a_t_t
Topics: 25
Images: 82
Extra Info: cl rwd
Postby Wiley » July 1st 2020, 5:31am
Yup, and on top of that, adding a lift will stretch the already short oil cooler lines, and tons of people do at least a 2 inch lift on these, so they are begging to be deleted!
Wiley
Postby drameydramey is online! » July 1st 2020, 8:02pm
“Did you keep the factory radiator, and tie in the auxiliary transmission cooler into that loop?”
Yes
“I'm thinking of going with electric fans too. I need to research into doing that, as it will be my first time doing it. Is it pretty straight forward to do?”
I used 2 electric fans with shrouds from a junkyard. I built some brackets to mount the 2 fans onto the radiator and wired the fans to kick on around 200F to 210F. I did away with the factory fan shroud.
Topics: 12
It is currently July 9th 2020, 5:32pm
Yuip
Time: 5:11pm
Comments: 14
Date: Jul 07 '20
Time: 6:27am
Comments: 9
Date: Jul 03 '20
Time: 6:15pm
Star Stuff
Comments: 87
Date: Jul 03 '20
Time: 4:22am
Attached by: ri$e*above
ri$e*above
Date: Jul 03 '20
Time: 1:14am
Users browsing this forum: drameydramey is online!, SlimeSlime is online! and 9 guests
