Incorrect Fuel level readings, bad pump?
Postby pmou [OP] » July 13th 2020, 9:27pm
Hey all,
I picked up a 2003 GMC Safari with 119k on it. The PO it seems was a total fool so I am not trusting any work that he did at this point. He said he replaced the fuel pump, and after that the fuel gauge reads way above full when filled, and then drops super fast for the last 1/4 or so ? I have not tried to verify this exactly as I haven't wanted to get stranded. He said he installed a pump from autozone (as all parts he installed :banghead: ). Today the gauge is just under 1/4 tank and the DIC says 111 miles to empty which seems like it might be slightly off? (27 / 4 = 9 * 16 = 144 miles til empty) but maybe is just a discrepancy or they leave some padding in the estimates. The DIC did not originally come from this vehicle so maybe it's off as well. Also, I use a phone bluetooth OBD2 reader which has worked great for me, but it doesn't give me any fuel pressure reading, just blank which also seems odd.
What I'm wondering is: is this pretty standard for POS pumps? Should I be able to read the fuel pressure from the OBD2? Is it possible that they installed a pump for the older smaller tanks or something and that's why the reading is off? Anything else I can easily test?
pmou
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Alias (AKA): Paul
Extra Info: V6 AWD 3.73 no LSD
  • 94 Astro no start after fuel pump install
    by grimbeardsly » June 7th 2020, 1:16pm in Engines
    Last post by grimbeardsly View the latest post
    June 21st 2020, 2:18am
  • No start after new fuel pump
    by Mberry0614 » June 19th 2020, 5:21pm in Engines
    June 24th 2020, 10:29pm
    September 26th 2020, 8:06pm
Re: Incorrect Fuel level readings, bad pump?
Postby M_a_t_t » July 13th 2020, 9:42pm
There is no fuel pressure sensor so it won't be able to tell you.
The fuel gauge is kind of weighted towards the low end. In my 95 van (could be OEM sending unit/pump, unsure) it is full for awhile and once it hits ~1/2 it starts dropping quickly. It's also possible he bent the float arm when changing the pump which would alter the reading.
Also you say pump, but do you mean the whole assembly? The part that controls the fuel gauge doesn't have to be replaced when changing the pump. Most people change them out, but if he was just trying to get rid of it and spend the least amount of money possible he might have only changed the pump.
It sounds fine to me though.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby pmou [OP] » July 13th 2020, 10:01pm
M_a_t_t wrote:Also you say pump, but do you mean the whole assembly? The part that controls the fuel gauge doesn't have to be replaced when changing the pump. Most people change them out, but if he was just trying to get rid of it and spend the least amount of money possible he might have only changed the pump.
Would this be the fuel sender? I have no idea what was actually done, he said pump but it was his dad or something (who didn't speak english) that did the work so who knows. After looking through a bunch of threads here about people overtightening the straps, etc.. I'm wondering if it might be worth just trying to get a closer look and see what I find. Thanks for the input! Definitely good to know that there is no fuel pressure gauge, that was a bit worrisome.
pmou
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Alias (AKA): Paul
Postby Leeann_93 » July 13th 2020, 11:59pm
Fuel level sender. There's what GM calls the 'hanger assembly' - which is the pump and the fuel level sender and a piece of hose that connects the two.
He probably replaced just the pump and put the old fuel level sender back in. The float might be bad, the wiring got messed up, who knows?
Postby Mmusicman » July 14th 2020, 4:02am
The fuel level sender (attached to pump) is controlled by a float on a thin metal arm.
This arm needs to be bent (adjusted) properly to match bottom position of tank when empty.
My previous fuel pump (sender) would read empty when I still had about 5 gallons... it was pretty far off. Sometimes I would drive for a couple days on empty. I made sure my recent new pump was aligned properly. The only trouble is that now when it says empty... I no longer have a few gallons kicking around, it's EMPTY. But it stays on full a little longer.. lol.
When the "variable rheostat" is all the way down... the float (on wire arm) must also reach the bottom of tank.
In this photo, I bent the arm down slightly a little more, to match the end of the rheostat travel.
Understand that the pump (AND the sender) are spring-loaded together.. so if the float arm is sticking up a little, it will always be off alignment.
Here's a closeup of the rheostat... (click photo to zoom)
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
It is currently September 26th 2020, 8:06pm
Comments: 48
Time: 9:45pm
Isuzuguru
Date: Sep 21 '20
Time: 5:20am
Maddog
Comments: 32
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 32
Date: Sep 18 '20
Time: 10:47pm
Maddog
Comments: 32
Date: Sep 18 '20
Time: 10:43pm
Users browsing this forum: Google Adsense [Bot] and 16 guests
