Engine Mount Comparison
Postby tonydobbs [OP] » July 29th 2020, 5:41pm
After hearing some conflicting opinions from forum members I ordered two different brands of engine mount. Finding information on this subject is a bit challenging, so I want to share my thoughts. Overall it seems clear that the Napa brand mounts have a higher quality stamping. The quality of the rubber seems very similar. The Napa ones have an oil coating, which makes them look a bit better, but the Anchor brand actually seems to have a bit more rubber. I will be installing the Napa ones in my van.
tonydobbs
Years of Membership: tonydobbs has been a member for 1 full year
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Re: Engine Mount Comparison
Postby CopperFiremistCopperFiremist is online! » July 29th 2020, 6:01pm
Don't forget to use a step drill bit to open up the holes a tiny bit, You'll thank me later.
Pullin The Pass
Blue Status (L2)
Blue Status (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby tonydobbs [OP] » July 29th 2020, 6:11pm
CopperFiremist wrote:Don't forget to use a step drill bit to open up the holes a tiny bit, You'll thank me later.
Good call! Thanks for the tip!
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby MechBob » July 29th 2020, 6:38pm
LOL,was thinking about this earlier, as there was yet another youtube astro MM vid.first a bit of history--
1 2wd and awd mounts are/were different.AWD original mounts were offset-the rubbers inside were offset,front to rear.
2 GM quit making them a long time ago
3 Anchor used to be the standard of quality,equivalent to factory,but seems they have went the china cheapo way
4 GM still sells the 2wd mounts,and some places sell them as awd mounts,they seem to sit lower,not recommended you try them, at almost 50 bucks a piece.Unless you have a 2wd
5 NAPA visually seems to have the best quality,of all the cheap china mounts.GM mounts are made in Korea
6 2 different poly insert mounts,Prothane and Energy Suspension.
7 Prothanes are only listed for 2wd,and do sit lower if put in an awd.this has been verified by others.To the point they shim them up
8 Buy general consensus on the net,Energy Suspension mounts are softer than Prothane
9 I have wondered about using cheap mounts(only ones we can get for awd,lol) and filling the gaps with 2 part urethane,like the rice burner street racers do.They make the 2 part stuff in 4 different "hardness's" Just food for thought.
10 OK done,lol!
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby tonydobbs [OP] » July 29th 2020, 6:42pm
Thanks for your thoughts Bob. One thing to point out is the Anchor branch ones say "Made in Korea" just like the GM ones.
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby tonydobbs [OP] » August 7th 2020, 4:55pm
I ended up using the Napa mounts and so far the van feels great. In the future I may try other mounts, but I just needed to get this done. I may be making some poly subframe bushings in the near future though, so I will let everyone know how that project turns out!
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby dcsleeper » August 7th 2020, 7:28pm
Thanks for this thread and the pics. I've made up my mind now, NAPA.
For next time:
https://www.homedepot.com/p/Loctite-PL-S30-10-fl-oz-Black-Polyurethane-Roof-and-Flashing-Sealant-1675273/203163733
Profile | Edit signature
1lowcab wrote:A one eyed, thumbless drunk monkey could reflow a wiper board, takes no special skill set.
dcsleeper
Images: 47
Postby Ironsides » August 14th 2020, 1:49am
Thanks Tony. Can clearly see the difference between the two.
Your 2435 are the same as the 2436
I need to learn more of these prothane bushings Bob speaks of.
Ironsides
Years of Membership: Ironsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full years
Topics: 5
Images: 3
Van Model Year: 2001
Extra Info: RWD Custom HD
Postby M_a_t_t » August 14th 2020, 5:35am
I have the energy suspension mounts in my V8 van. Haven't had them on very long. About 150 miles, but has felt very smooth even with the v8. I also have all new suspension and it has been riding very well so any mount problems should be more evident I would think.
I blasted and powder coated the OEM clam shells then used bolts to hold them together until assembly. The bolt heads were too tall though and hit the frame before the clamshells seated. I was lazy and put a few washers between the frame and mounts to fix it.
102332
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby Ironsides » August 14th 2020, 12:06pm
Hi Matt, those look nice and new, good job. Yours fit, they're '95.
I still haven't found my OEM ones :eusa-think: I keep all the steel parts for recycling.
Tony's second image posted above shows a difference in height between the other and new style. If NAPA makes them to the new specs I'm guessing that's why they don't fit. Good to Know they ride nice with a V8 sitting on them.
Ironsides
Topics: 5
Images: 3
Postby Ironsides » August 17th 2020, 3:29pm
Found them... https://www.prothanesuspensionparts.com/7521 in case anyone else is looking.
Poly insert engine mounts for rear wheel drive RWD. I know you weren't looking for these Tony but thought to put this here in case anyone else went looking and stumbled on your thread.
Ironsides
Topics: 5
Images: 3
It is currently September 22nd 2020, 1:57am
Isuzuguru
Time: 5:20am
Maddog
Comments: 31
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:47pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:43pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:40pm
