So I've already read through a bunch of the threads on coolant leaks, but still not quite sure how to proceed so I figured I'd start a thread. The situation seems to be as follows:
1. The past few days I've driven my 1999 Safari to the store and back, which is all of five minutes each way. By the time I get to the store, it's clearly leaking, and when I come back from shopping there's like 1/4-1/2 cup of fluid on the ground. However, when I drive home (again, just five minutes) and park, by that time there's BARELY any dripping, nothing like it was at the store. So it seems like this is only happening when it's cold/starting up. Once the van has been driving for a while, it seems to simply stop leaking.
2. Today I decided to open the hood and fire it up in the driveway. Let it do that for a good five minutes - just idling, revved it a little to see if anything happened. MAYBE there was a TINY bit leaking out somewhere - I could see some little specs around that brace near the water pump, but really not anything I'd consider noticeable or a problem. Then I backed it up 25' and then forward again - bingo. All of a sudden there was coolant being sprayed around the front of the engine - to be clear the leak only seems to be in the front, nothing is ever leaking off the back. The problem is it's getting onto the serpentine belt so quickly, and that's just spreading it all around the whole area so quickly it's hard tell where it's coming from. (also, yeah, safety glasses next time)
3. I checked the oil - it's not looking "milk shake-ey" in the slightest, so doesn't seem like coolant is getting into the oil.
4. The van has 150k miles on it.
The obvious answer here seems to be the water pump is on the way towards failure, but just wanted to see if anyone else had any other opinions on it.
-Sky
