Hi! My Astro has started having a(nother) problem.
I was driving up Snoqualmie Pass in WA and then out into the dirt roads in the mountains. Right when I was heading to the trailhead, on a dirt road going up a slight incline after a long hot drive, my van's engine stopped working momentarily. I still had radio, so the electricity was still there. The van cut and then turned back on after cutting one or two times. The van was fine for about 100 miles or so.
I replaced the fuel pump relay as it was pretty chewed up and I thought this might've been the cause. I checked the voltage at the battery and it was 12.3 V and after the lights were on for 1 minute it was at 11.6. I thought I'd fixed it as I didn't have the problem on a long drive I took after replacing the relay.
On Saturday I drove back into the mountains and on the way home the engine started cutting again. It was much worse. Again, the weather was pretty hot and I'd been driving for quite a while if that makes a difference. The engine cut then came back on. It then cut a couple more times and was much less interested in coming back on. It really started sputtering. I pulled off the road I was on and stopped the van. I turned it back on again and made it the rest of the way home without incident.
Yesterday I drove to the store and the van cut as I was rounding a corner. It was really hot out, but I had only been driving for maybe 5 minutes.
Is this the fuel pump going out? Or something different?
Thanks for all the help y'all give. I am extremely grateful for this forum.
