Correct Oil Pressure Reading
Postby Safarimeister [OP] » August 19th 2020, 12:42am
I recently switched from 5W30 Conventional to 5W30 Full Synthetic. I have never paid a lot of attention to the pressure gauge, but while driving on a long road trip down to Phoenix, I did notice the oil pressure would drip below 40 and sometimes making its way back up to 40 at highway speeds. Keep in mind, outside temps have been between 92-115.
When I would slow down or stop, my gauge would read around 20.
On cold starts, it usually shows around 40.
Vehilce has 200K on it.
Should I go with a higher viscosity oil or is this normal?
Safarimeister
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Safarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full yearsSafarimeister has been a member for 7 full years
Topics: 20
Alias (AKA): Safarimeister
Extra Info: 4WD G80 GT4 JOR5
  • Oil Pressure Specs
    by AveryStella » December 20th 2020, 12:52am in Engines
    December 27th 2020, 1:57pm
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    46
    January 22nd 2021, 5:45pm
Re: Correct Oil Pressure Reading
Postby Big_kid » August 19th 2020, 12:57am
Old racer's rule says 10PSI for every 1000 RPM. According to that, you're fine. Seems like pretty good readings to me for having 200K on it. Keep in mind the dash gauges aren't the most accurate, they're there so you have an idea what's going on in your engine. "Real" numbers would require a mechanical gauge. Since you're not posting about a knocking sound and overheating, I'd say you're fine.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Postby Safarimeister [OP] » August 19th 2020, 1:11am
Thanks for the quick reply. I just drove 1800 miles to PHX. Two 13 hour days. The engine is real quite, except under load my idler bearing or water pump is growling like crazy.
I just dropped it off at Journeys Offroad for a lift, all new suspension, radiator idler bearing, water pump and a few more things.
I don't want to run into any issues on my way back up to Minnesota.
Safarimeister
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 20
It is currently January 22nd 2021, 5:45pm
Date: Jan 10 '21
Time: 7:37pm
roachmonroachmon is online!
Date: Jan 10 '21
Time: 4:04am
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
pmou
Comments: 71
Date: Dec 31 '20
Time: 4:12am
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 21 guests
