Need quick response on hissing and missing
Postby Jawon [OP] » August 31st 2020, 2:59pm
After a one hour trip in high temps, engine started hissing like release of air and then steering and braking immediately became stiff. After resting an hour, I tested around a parking lot and it went back to normal
Took it to the mechanic and I got a very fishy diagnosis. They said the cause was the belt tensioner was missing. Bolt was still loosely on but the actual tensioner was gone.
Would I have been able to drive around the parking lot with a missing tensioner? Is it possible a tensioner could disappear leaving the bolt in place? How does that solve my original hissing problem?
I feel like I’m getting duped.
Jawon
Years of Membership: Jawon has been a member for 7 full yearsJawon has been a member for 7 full yearsJawon has been a member for 7 full yearsJawon has been a member for 7 full yearsJawon has been a member for 7 full yearsJawon has been a member for 7 full yearsJawon has been a member for 7 full years
Topics: 25
Van Model Year: 1996
Extra Info: 4.3L
  • I Need Subframe Drop Advice
    by Sparkydog » September 21st 2020, 3:12pm in Engines
    September 26th 2020, 6:09pm
  • P301 rough idle need help with proper diagnosis
    by StillSmiling » January 27th 2021, 6:14am in Engines
    Last post by StillSmiling View the latest post
    February 2nd 2021, 1:21am
    March 6th 2021, 5:47pm
Re: Need quick response on hissing and missing
Postby M_a_t_t » August 31st 2020, 3:14pm
I don't see how a belt tensioner can "fall off" (or break off?) and leave the bolt there.
One time I had the pulley on the tensioner start to lock up and it pushed the belt off enough that I lost P/S and brakes intermittently. So I suppose it is possible, but the fact the bolt is still there seems fishy.
If you can I would put the tensioner back on yourself, if you have to buy it from a local store even. It might be hard to do without removing the fan shroud though. The details just don't add up.
Is the belt still there, just no tensioner?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 27
Images: 96
Extra Info: cl rwd
Postby augidog » August 31st 2020, 3:51pm
if the entire tensioner "fell off" I'd think there'd be a god-awful mess under the hood.
however, I can venture a guess that something's wrong related to the belt drive (unsprung tensioner? tensioner pulley as Matt mentioned? idler pulley?) and it's affecting the hydroboost system, which likely explains the hissing, based on the described symptoms.
a picture will probably save a thousand words.
augidog
Years of Membership: augidog has been a member for 1 full year
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby Jawon [OP] » August 31st 2020, 4:04pm
augidog wrote:if the entire tensioner "fell off" I'd think there'd be a god-awful mess under the hood. however, I can venture a guess that something's wrong related to the belt drive (tensioner pulley as Matt mentioned? idler pulley?) and it's affecting the hydroboost system, which likely explains the hissing, based on the described symptoms.
Belt was apparently shredded. Idler pulley was also rough and replacement recommended. They did mention there was a little leaking at Hydroboost but replacement not needed at this point especially with $800 part cost (OEM?)
How does the belt drive affect Hydroboost? What could the hissing rush of air sound been?
Jawon
Topics: 25
Extra Info: 4.3L
Postby augidog » August 31st 2020, 4:10pm
better explained in detail by someone more experienced, but the accumulator holds enough pressure for a couple/few brake pumps...and if the system's not fully bled, there's a growl associated with it either discharging or recharging, I'm not sure which.
if it were me, I'd be doing a complete new serpentine kit.
my arms are long and I did it all without removing anything else.
augidog
Topics: 16
Alias (AKA): Augie
Postby MechBob » August 31st 2020, 4:11pm
Belt runs power steering pump.The pump provides pressure to the hydroboost.The hiss could have been a lot of things,even the shredding belt strands.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby M_a_t_t » August 31st 2020, 4:12pm
Hydroboost is powered by the P/S pump. If the belt is messed up then you loose power steering and power brakes. No idea on the hissing unless it was low on fluid and the pump was just starting to whine.
1995 Mercury Tracer
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby augidog » August 31st 2020, 4:17pm
he mentioned a leak, and a "hissing rush of air" so could this be the accumulator burping?
augidog
Topics: 16
Alias (AKA): Augie
Postby Jawon [OP] » August 31st 2020, 5:16pm
Thanks so much for the quick responses about the tensioner. This might be distracting the real issue so let me go back to the hiss
It was wifey who was driving at the time and described the situation to me. The hissing was definitely air not rubber or metal. Engine was running for an hour when this happened. It happened about three times each time she tried starting the car. It was prolonged and stopped only when she shut the engine off. Brakes and steering stiff.
An hour later, I drove around the parking lot and heard no hissing and the brakes and steering were perfectly fine.
Could there be a loss of vacuum or a deteriorating hose that could have caused this? Tensioner doesn’t solve this. The tensioner diagnosis feels fabricated.
Jawon
Topics: 25
Extra Info: 4.3L
Postby MechBob » August 31st 2020, 5:19pm
Get the belt,tensioner and idler stuff fixed,then worry about the noise.One step at a time.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Jawon [OP] » August 31st 2020, 6:46pm
Got more clarity from the mechanic. It appears the tensioner arm and pulley somehow broke off and is nowhere to be found. But the spring housing is partly there still. Photo attached.
Mechanic states it could be possible to drive around the parking lot for a short time without steering or braking issues, as I did, even without the belt.
As suggested here and by the mechanic, I’m gonna get a new tensioner, idler pulley and belt installed. Then see if hissing noise persists. I’m tempted to do myself but it’d be a hassle getting the van back and my time is limited and it seems the mechanic may not be duping me after all. And at 160k miles, I’m inclined to let a pro give it a good look over.
Thanks for all the opinions.
Jawon
Topics: 25
Extra Info: 4.3L
Postby augidog » August 31st 2020, 7:03pm
wowee! someone here likes to say "pics, or it never happened." well...it happened !
first, I agree you can't know more until you get the new serpentine kit on there.
second, no water pumping could certainly result in some hissing. or...damaged radiator, cooling hose, or unrelated line, from when the tensioner bounced it's way out of there.
I'll keep my fingers crossed for a good outcome.
augidog
Topics: 16
Alias (AKA): Augie
Postby Leeann_93 » August 31st 2020, 10:40pm
Wow. I've never seen that happen.
I guess the tensioner or idler (or both) could have seized and caused that, but I'm a little questionable on that. You should have heard nasty noises for a long time before that happened if that was the case.
I guess we shall see.
It is currently March 6th 2021, 5:47pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Users browsing this forum: ThemistoclesThemistocles is online! and 27 guests
