Piston ring gap question
Postby observer [OP] » September 14th 2020, 6:30am
I have the chance of setting the ring gap of a set of file-fit rings. My Haynes, Chilton, and factory service manuals all call for gap of 0.01-0.02" for the 1st (top) compression ring.
Has anyone ever set the gap at the lower end of 0.01" and ran into problems?
Assuming thermal expansion coefficient of steel of 1.3x10^(-5)/C, 0.01" ring gap, and piston diameter of 4", these translate to a max allowed temperature difference of 60C between the cylinder wall and the ring (before the gap closes).
60C does not seem a lot to me, but then I am no expert in engine thermal models. Not sure if 60C will be sufficient.
Thanks for any input!!
observer
Years of Membership: observer has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full years
Topics: 12
  • Unable to get fuel pump lock ring to lock on my 1994 Astro.
    by blendergasket » September 8th 2020, 2:16am in Engines
    Last post by blendergasket View the latest post
    September 19th 2020, 4:30am
  • Setting timing question
    by hotpsca » July 17th 2020, 11:35pm in Engines
    Last post by hotpsca View the latest post
    July 18th 2020, 12:55am
    October 29th 2020, 5:57pm
Re: Piston ring gap question
Postby chevymaher » September 14th 2020, 11:12am
My engine builder did on my boats 3 liter. It got hot rings end butted and destroyed 2 cylinders. Best go the loose end and clock the ring butts 90 degrees on the piston.
Postby K-TRON » September 18th 2020, 4:13am
I rebuild a lot of air cooled engines, and 0.010" is pretty tight for an upper compression ring. Water cooled engines run substantially cooler than an air cooled engine so I see no reason why 0.010" end gap would cause problems. You can always just go to a happy medium and set them at 0.015". The most ring related problems are from improperly bored/honed cylinders, dirty ring grooves or the wrong types of rings used.
Chris
K-TRON
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: K-TRON has been a member for 6 full yearsK-TRON has been a member for 6 full yearsK-TRON has been a member for 6 full yearsK-TRON has been a member for 6 full yearsK-TRON has been a member for 6 full yearsK-TRON has been a member for 6 full years
Topics: 13
Extra Info: 4.3L V6 AWD SLE
Postby gman » September 21st 2020, 6:51am
Never rebuilt an engine, but using the coefficient of expansion of steel is probably not a good idea, as that is probably applied to something that is 100% steel.
Lot's of things can be called "steel", and unless you know the exact chemical makeup of the rings, it's probably not going to be accurate.
Unless you can verify that the rings are made of 100% steel, I wouldn't use the coefficient of expansion.
Many things can be considered steel, and all of them have different makeups as far as composition goes.
You could use it to approximate, which it seems like you're doing.
1999 Chevy Astro Van
gman
Topics: 35
Images: 39
Extra Info: Base 4.3 RWD
It is currently October 29th 2020, 5:57pm
Buzman63
Date: Today
Time: 2:06pm
kade225
Time: 11:27pm
djpigs
Date: Oct 27 '20
Time: 10:01pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Users browsing this forum: No registered users and 31 guests
