Taller Motor Mounts?
Postby Sparkydog [OP] » September 28th 2020, 6:32pm
I'm going to put 3" spacers between body and subframe when I do my lift. I've read some comments elsewhere on the forum about maybe some of you have spaced your motor up a little when doing the lift. I was thinking of doing a 1 to 1.5" spacer of some sort. I tried a search using "motor mounts" but only got the usual results for how to replace them - nothing about increasing the height of the motor above the frame.
Has anyone done this and what tips do you have for me? Thanks!
Sparkydog
Years of Membership: Sparkydog has been a member for 1 full year
Topics: 12
  • AWD Motor Mounts question
    by jaack » July 28th 2020, 6:03am in Engines
    Last post by jaack View the latest post
    July 29th 2020, 10:19pm
  • About to do my Engine/Transmission mounts (Please Help!).
    by gman » July 9th 2020, 5:22am in Engines
    Last post by gman View the latest post
    July 9th 2020, 6:26pm
    11
    December 3rd 2020, 10:12pm
Re: Taller Motor Mounts?
Postby SportsBoySportsBoy is online! » September 28th 2020, 8:17pm
I think turnNburn and the user Lumpdog have both done it - It seemed like for every inch of rise, you need to angle it towards the centerline of the car so it is still in the right spot to mount to the engine - if that makes any sense.
Check out their builds and you'll find the pics of what they did.
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby Birdshake » September 28th 2020, 9:28pm
I've been wanting to do this too. After installing poly mounts the oil pan is no longer resting on the front axle but it is still way to close for comfort.
https://www.astrosafari.com/viewtopic.p ... 7#p1237193
Lumpdog wrote:I used engine plates from Chassis Unlimited to build the motor mount spacers. Four of the plates and a 1" spacer in between them makes them 1.5" tall. Then offsest the mount plates 1.5" from eachother and when mounted on a 45 degree angle it lifts the motor 2.12". Then for the transmission mount I just used a piece of 2" box tube. Easy peasy.
http://www.chassisunlimited.com/product ... lates.html
I also extended the steering shaft 5" as well.
But the 5" drop and one inch move forward was easy. Rear is lifted with some s10 leafs, an add a leaf, a 1" block, and 2 longer ubolts and 4 1/2" bolts. It was easy too. I haven't done the shackles yet, but don't think I will need them. I think I have all of $100 into the whole lift plus my time.
It doesn't seem like that company is offering those plates anymore so I am looking into making them myself now. I have scrap 3/16" plate sitting here but those plates are 1/4" I think 3/16" will be fine but I'm not 100% sure.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full years
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Postby Sparkydog [OP] » September 28th 2020, 9:34pm
Thanks Sportsboy and Birdshake - I read lumpdog's posts about the motor mount spacers and now I think I have the basic concept. I think I'll fab my own plates.
Sparkydog
Topics: 12
Postby MechBob » September 29th 2020, 2:29am
Really not an uncommon thing,have seen it talked about on s10-blazer and mustang sites,esp. with poly mounts.Some have just spaced them up with washers.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby AstroWill » September 29th 2020, 2:56am
Birdshake wrote:I've been wanting to do this too. After installing poly mounts the oil pan is no longer resting on the front axle but it is still way to close for comfort.
I feel the same way about my 03, I have been considering putting some spacers in there if I ever have to pull the engine for anything. I would like to strap a camera down there sometime and run it hard, see how much movement I'm actually getting and if I should really worry about it.
Images: 443
Postby MechBob » September 29th 2020, 3:24am
I still wonder about these old vans,ones that have been used hard,on bumps,that the frame rails have started to roll downwards.Like perhaps that fellows down in South America,don't think we heard back from him? Only a good frame machine.measuring would tell.But,i did craw under mine,the 94 had new,aftermarket, mounts,back when i rebuit the motor,and they are starting to sag.My 96 are original,211,000,I think, and still look pretty good,good clearance.But I do not hammer it.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Sparkydog [OP] » September 29th 2020, 4:41pm
I'm not sure if the motor mounts are on an actual 45* angle - but just eyeballing it they seem close to 45*. And if that angle really is 45, then the trig works out to:
If you add a 1" spacer plate(s) the motor will be raised 1.4" and the hole pattern on either the motor or frame side of the spacer will need to shift 1".
If you add a 3/4" spacer plate(s) the motor will raise 1.06" and the hole pattern will need to shift 3/4".
Sparkydog
Topics: 12
Postby Unclebilly » October 16th 2020, 5:17pm
DId you ever get the van lifted? I just did mine with 5 inch spacers when I replaced the engine. The motor mounts were not hard to make.
Unclebilly
Van Model Year: 2002
Postby markmitch » October 16th 2020, 5:34pm
I bought some 1/4 inch plates to put under mine for now and made a 1/4 inch late for the trans mount to match it. But this is a long project so I can't say how much it helped yet.
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby Birdshake » October 16th 2020, 6:53pm
I drew up a quick design for the plates. I got a quote from a local waterjet place and I can basically cut these out myself for quite a bit cheaper.
MM PLATE.pdf
(93.76 KiB) Downloaded 19 times
245/75/16 BFG KO2
KYB Monomax
Birdshake
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Postby nico541 » October 19th 2020, 9:11pm
Was reading an article about LS swaps and they mentioned Headman is a good resource for adapters and brackets. Took a look on their website and found these
https://www.hedman.com/product-detail/4125
$21 you holla
nico541
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: nico541 has been a member for 7 full yearsnico541 has been a member for 7 full yearsnico541 has been a member for 7 full yearsnico541 has been a member for 7 full yearsnico541 has been a member for 7 full yearsnico541 has been a member for 7 full yearsnico541 has been a member for 7 full years
Alias (AKA): nico541
Postby Sparkydog [OP] » October 20th 2020, 4:05pm
Once I actually got my hands dirty and removed the old motor mounts I changed my mind on how to do the spacing. I realize that what I did may not work for other people - but for me it was "easiest" to modify the motor brackets. I made up a dirt simple spacing jig that had two holes spaced 1.5" apart and modified a couple of bolt shanks so they fit tight in the holes, then clamped on my extender pieces and used a 45* carpenters square to orient things and then welded it all up. I also replicated the weird little notches in the bracket arms that mate up with the weird little nubs on the new motor mounts.
And then machined some simple 1.5" tall pucks for the transmission mount.
Sparkydog
Topics: 12
Postby Sparkydog [OP] » October 20th 2020, 5:47pm
Sparkydog wrote:I'm not sure if the motor mounts are on an actual 45* angle - but just eyeballing it they seem close to 45*. And if that angle really is 45, then the trig works out to:
Once I had the brackets and mounts out of the van I confirmed with an angle gauge that the engine block and the subframe are at 45* angles.
Sparkydog
Topics: 12
It is currently December 3rd 2020, 10:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Users browsing this forum: No registered users and 27 guests
