Let's Look at My Spider and Intake Stuff
Postby Sparkydog [OP] » September 29th 2020, 3:36pm
Do I have the good spider? Is it normal for the intake plenum to have this much oily goo coating everything? Should I do anything more than clean up all the parts and put them back together?
114,XXX miles. Thanks for your comments!
Sparkydog
Years of Membership: Sparkydog has been a member for 1 full year
Topics: 12
  • Let's Look at My #3 Cylinder Wall
    by Sparkydog » October 13th 2020, 8:54pm in Engines
    Last post by Sparkydog View the latest post
  • intake manifold gasket help
    by Sp3cialNe3dz » September 23rd 2020, 8:22pm in Engines
    Last post by Sp3cialNe3dz View the latest post
    September 26th 2020, 12:50am
    18
    March 5th 2021, 8:04am
Re: Let's Look at My Spider and Intake Stuff
Postby Mmusicman » September 29th 2020, 4:23pm
Can't tell if a spider is good simply by "looking at it".
If it develops problems.. you'll usually KNOW it!
Your intake looks nice however... :D
Oily-goo.. I'm not sure...
If the regulator is leaking.. that would be detected in a pressure leak-down test.
Someone else may be able to offer more on the photos..?
Topics: 73
Images: 49
Postby Sparkydog [OP] » September 29th 2020, 4:33pm
I meant "Is this the preferred style of spider? Do I need to upgrade?"
Sparkydog
Topics: 12
Postby M_a_t_t » September 29th 2020, 5:28pm
03-05 had the better version stock. So yes it is the version you want. No idea on the goo either.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 27
Images: 96
Extra Info: cl rwd
Postby WoodButcher » September 29th 2020, 5:52pm
Oily goo is okay/ normal, when you see a clean spot that's when you have something leaking.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Leeann_93 » September 30th 2020, 10:52pm
Actually, 02-05 has the MFI spider installed from the factory, so yes, you have the 'good' version.
The plenum doesn't look bad at all. Oily (actually, carbon from combustion plus a little gas) goo is normal unless it's excessive.
The plenum on my '02 (also MFI) looked far, far worse than that when the #4 injector failed electrically (the wire burned):
The '05 wasn't as nasty as the '02, but there are clear washed and dirty areas from leaking injectors:
This is the underside of the throttle body on the '02 - definitely worse than yours:
So I say, clean everything and reinstall. Though you can plug the spider back in and energize the injectors with a scan tool to see if anything's dribbling.
It is currently March 5th 2021, 8:04am
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Users browsing this forum: No registered users and 15 guests
