removing rear heat
removing rear heat
Postby Sp3cialNe3dz [OP] » October 4th 2020, 7:11pm
what can i do away with? i'm looking just to run front heat. i just have the 4 port heat valve and then the four season rear valve 2 port. can i some how just run the four port?
Sp3cialNe3dz
Topics: 10
Alias (AKA): Eric
Extra Info: awd handicap
  • Rear main seal retainer bolts?
    by Geek » November 4th 2020, 9:56am in Engines
    Last post by Geek View the latest post
    7
    94
    March 1st 2021, 1:19am
Re: removing rear heat
Postby M_a_t_t » October 4th 2020, 7:24pm
On my front heat only van the 2 hoses run from the water pump and front of intake to the heater core. You should be able to just remove all of it and just run the 2 hoses like that if you want the simplest setup. You can also loop the rear lines and not mess with anything else. Leeann_93 has some good pictures around here somewhere showing how to do that. I don't have it handy though.
Also, if you click the "Img" tag above the reply box and copy paste that link address for that picture you wouldn't of had to attach it. I find it easier that way.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 27
Images: 96
Extra Info: cl rwd
Postby AstroWill » October 4th 2020, 9:48pm
Technically you could bypass enough to get rid of everything except the vacuum source to the firewall pass-through.
That would still be needed to control the vents, and the vacuum storage ball is worth keeping, otherwise the vents can lose vacuum under certain situations(think long steep hills).
Images: 472
It is currently March 1st 2021, 1:19am
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: No registered users and 25 guests
