Oil/Coolant mixing Troubleshooting
Postby hankheat [OP] » October 7th 2020, 6:19pm
I posted last week about an issue I noticed a week or so after buying a used 2000 2WD Astro LS v6 with 100k on it. Everything seemed normal, no lights or codes, exhaust clear, no smoke, but with the engine warm, at higher speeds or quicker acceleration the power would dip. Not stall but dip.
I checked the fuel pressure (normal) and pulled the plugs. Then I noticed coolant leaking from the heater diverter valve. I put some dye in the find the leak. My radiator cap was gummed up with rusty looking deposits. I drained a couple ounces of oil and put a couple drops on a hot manifold & heard crackling.
So now I'm wondering if I have a blown head gasket. But I'm not seeing milky looking oil on the oil cap or dipstick. And again no white smoke.
My best guess is to drain & flush the coolant system and change the oil, and the plugs.
My question is: Is this condition so bad that I should NOT start the engine again? Any advice at what to do first? Is there a correct order of operations? Is it useless to do anything until I replace the head gasket? Do head gasket sealers work? And if the oil & coolant are mixing does that mean a sealer would seize the engine?
I do have a scan tool & app if there are helpful measurements to look at.
Halp. Thank you.
A look inside the radiator
Deposits along the top of the coolant reservoir
Oil drained from pan
Plug Position 1
Plug Position 3 (Both are lighter on 1 side & darker on the other, shown is lighter side)
Radiator cap
Throttle Body (before cleaner)
Throttle Body open (before cleaner)
hankheat
Extra Info: LS 4.3L V6 RWD
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
  • coolant leak detective
    by fourwheelwheelie » July 18th 2020, 9:29pm in Engines
    August 13th 2020, 11:53pm
    December 3rd 2020, 9:34pm
Re: Oil/Coolant mixing Troubleshooting
Postby hankheat [OP] » October 7th 2020, 6:30pm
More pics
Oily valve cover, dry & rusty beneath
Leaking heater diverter valve
Lots of rusty looking areas beneath radiator but dry
hankheat
Postby dcsleeperdcsleeper is online! » October 7th 2020, 7:05pm
I wouldn't condemn the head gaskets just for that, "crackling".
Your plan sounds good.
replace that heater valve, they are known to fail just being touched.
Profile | Edit signature
Lumpy wrote:You can weld a cheese sandwich to a shower head and add a blind side bracket for a baboon circumcision tool holder if you want to...
Topics: 18
Images: 59
Alias (AKA): DC
Postby markmitch » October 7th 2020, 8:33pm
Also it could be an intake gasket. drain the radiator. grab a gallon jug add 1 cup of cascade dish washer powder in the jug then fill with warm water. Shake it good then close the radiator petcock add the mixed water and powder then fill with water only. start the engine let it run for 45 minutes. buy one of these and cut the 3/4 inch hose and add the T.
https://www.ebay.com/p/1022074711?iid=3 ... 4sQAvD_BwE. hook a hose to the t turn the water on then start the engine and open the drain thing again. In the kit is a part that attaches to both the t and to the hose put that in place prior to turning the water on. You may get wet doing this. let it run again till water coming out is clear. this will clean out the oil in the cooling system.this must be done with heater on full and if you have a rear heater turn it on too.
Once its coming out clear , turn water off and allow to drain. then in your case I would just put water in till you figure out the rest of the problem. Also drain the engine oil and fill with cheap stuff and change the filter, run for a while then change it again. I would do this a few times but again figure out where its coming from first. Hope this helps, Mark
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby hankheat [OP] » October 8th 2020, 12:53am
Thanks for those suggestions.
hankheat
Postby AstroWill » October 8th 2020, 7:48pm
I would fix your leak, then pressure test the system to see if/where there are any more leaks. A lot of LAPS will let you borrow a pressure testing kit.
I wouldn't stress and start jumping to conclusions just yet ;)
Images: 443
Postby dcsleeperdcsleeper is online! » October 8th 2020, 10:33pm
Always there with a good suggestion, Will
Are you turning Japanese? :)
Topics: 18
Images: 59
Alias (AKA): DC
Postby sixsixsixsix is online! » October 9th 2020, 12:43am
dcsleeper wrote: ...
Haha
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby AstroWill » October 9th 2020, 12:46am
dcsleeper wrote:Always there with a good suggestion, Will
LOL, now I'm going to have a heck of a time getting rid of this earworm.
Images: 443
It is currently December 3rd 2020, 9:34pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
