whooooh What The .....
Postby djpigs [OP] » October 24th 2020, 7:22pm
I replaced head gasket and got everything working again,(was overheated.), was running good for a two weeks or so, had a knock when cold start but was not that bad....but now have a crack in oil pan and will not turn over...so figure something fell apart...>??????
djpigs
Years of Membership: djpigs has been a member for 3 full yearsdjpigs has been a member for 3 full yearsdjpigs has been a member for 3 full years
Alias (AKA): dj_pigs
Van Model Year: 1996
Extra Info: RWD
Re: whooooh What The .....
Postby Rod's Trucks » October 24th 2020, 7:40pm
I think pulling the oil pan will reveal the source of the problem, and it will not likely be a pretty sight.
Rod J
Rod's Trucks
Topics: 26
Images: 54
Alias (AKA): Rod and/or WE7X
Postby chevymaher » October 24th 2020, 8:23pm
So it hydrauliced a cylinder then threw that puppy under the bus huh.
Postby dcsleeperdcsleeper is online! » October 24th 2020, 10:08pm
The inside parts are making an exit...
Profile | Edit signature
Lumpy wrote:You can weld a cheese sandwich to a shower head and add a blind side bracket for a baboon circumcision tool holder if you want to...
Topics: 18
Images: 59
Alias (AKA): DC
Postby markmitch » October 24th 2020, 10:33pm
sounds like politics to me lol
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby sixsixsixsix is online! » October 25th 2020, 2:29am
chevymaher wrote:So it hydrauliced a cylinder then threw that puppy under the bus huh.
dcsleeper wrote:The inside parts are making an exit...
markmitch wrote:sounds like politics to me lol
LOL
:rofl:
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby Big_kid » October 25th 2020, 5:58pm
Sounds like it may have thrown a rod. Drain what's left of the oil and break open the oil pan. It's no good anymore anyway, it'll allow you to see what's happened inside.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby dcsleeperdcsleeper is online! » October 25th 2020, 7:54pm
and don't forget, PICs
Topics: 18
Images: 59
Alias (AKA): DC
Postby djpigs [OP] » October 26th 2020, 12:13am
OK, here is the issue, is it worth fixing? cost? I could probably get a whole sub-frame with motor and tranny for cheap...this is for off road use, not insured...rear wheal drive, so I am looking around right now.. :(
djpigs
Extra Info: RWD
Postby chevymaher » October 26th 2020, 12:23am
Only you can answer that. I did it twice so far.
Postby djpigs [OP] » October 26th 2020, 1:15am
so I figure I have to take off the heads , right? new gaskets?
djpigs
Extra Info: RWD
Postby AstroWill » October 26th 2020, 7:30pm
You are going to have to start at the bottom and find out all of what is broken. Then decide if you want to repair or replace, or scrap.
Images: 443
Postby Mmusicman » October 26th 2020, 10:36pm
AstroWill wrote:You are going to have to start at the bottom and find out all of what is broken. Then decide if you want to repair or replace, or scrap.
^ THIS. Stop guessing
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby djpigs [OP] » October 27th 2020, 10:02pm
OK here it is , the Crack.....on the shallow end..
djpigs
Extra Info: RWD
Postby Birdshake » October 27th 2020, 10:04pm
Yikes
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full years
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Postby Big_kid » October 27th 2020, 11:14pm
That oil pan is trash. Remove it, break it open if you have to, see what is on the inside. Something broke it, figure out what the culprit was.
Topics: 185
Images: 333
Postby Leeann_93 » October 29th 2020, 1:23am
OUCH.
Now you need to find out why the oil pan broke like that. Pretty sure you need a short block at the least, and a long block to make things easier.
On my '93 Astro, I have a quarter-sized hole because a lifter punched out the oil pan. You need to see what did that damage, because something inside is much, much more broke than that.
Postby djpigs [OP] » November 1st 2020, 11:59am
Something got hot...Get an Astro they said....
djpigs
Extra Info: RWD
Postby chevymaher » November 1st 2020, 12:10pm
WEEEEEE DOGGIES Well lookie there.
Postby Mmusicman » November 1st 2020, 1:18pm
djpigs wrote:so I figure I have to take off the heads , right? new gaskets?
Topics: 73
Images: 49
It is currently December 4th 2020, 5:33pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Users browsing this forum: No registered users and 21 guests
