4.3 half throttle stalls
Postby DAS2020 [OP] » October 27th 2020, 12:50am
This started today, idles fine, give gas say to half throttle it stalls sluggish almost dies. New cap, rotor, wires, plugs, may sensor, throttle position sensor metered ok. Seems to be catalytic convertor plugged? Could it be doing this?
Also fuel pump was changed about 50k miles ago, which I understand that doesn't mean anything.
I did have air intake tube off, running, and when it gets real sluggish I sprayed good carb cleaner in it, didn't make a difference.
DAS2020
Extra Info: 4.3L
  • 1996 Throttle cable
    by metalraider » October 27th 2020, 9:04am in Engines
    October 27th 2020, 2:05pm
    48
    March 1st 2021, 5:17pm
Re: 4.3 half throttle stalls
Postby DAS2020 [OP] » October 27th 2020, 2:22am
Just checked fuel pressure on rail, was 55 to 60 psi, stayed in that range.
Had it running, and stalling, check Temps on exhaust before catalytic convertor was 825, backside of convertor was 600 degrees. Could it be plugged, creating backpressure,?
DAS2020
Extra Info: 4.3L
Postby AstroWill » October 27th 2020, 3:23pm
Does it do this only when cold, or when warmed up as well?
Is that pressure with the engine off or running?
Pulling a front o2 sensor can quickly tell you if the converter is clogged, but you usually see that more at speed than at idle.
Images: 472
It is currently March 1st 2021, 5:17pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Google [Bot] and 29 guests
