Difference between 4.3 blocks?
Postby Buzman63 [OP] » October 29th 2020, 7:54am
Would a 94 4.3 block be compatible to a 03? Transferring heads, intake, ect.. Advise please and thank you!
Buzman63
  • Phisical differences between 98 and 2003 4.3 engine
    by chucksurette » June 8th 2020, 11:40pm in Engines
    Last post by chucksurette View the latest post
    July 18th 2020, 5:10pm
    9
    26
    December 4th 2020, 2:40am
Re: Difference between 4.3 blocks?
Postby chevymaher » October 29th 2020, 11:16am
Yes it all interchanges. It should be a balance shaft. If you get lucky they got extra block crank webbing on some of them. If you get the one with the metal timing cover. seal that damn crank trigger spot that is unused. JB Weld the piss out of it. It it pop riveted on and they leak.
Postby Buzman63 [OP] » October 29th 2020, 2:07pm
Very nice! Thanks for your fast reply!! This is my 4th astro, 1st 2nd generation, first awd. I am absolutely an astro fan as I have had nothing but good experiences and wouldn't give my most recent up for anything. (86,91,94 and 03)
Maintenance is key (I'm semi retired) and being a house mechanic whom hates getting greasy(not a wuss, just wasn't my thing) l have dug in and learning to get it done.. questions: what is block crank webbing? How far should I tear down the donor? Oil pan\pump the same? Yes it has the balancer.
What parts can I use from either to be the most efficient? Thanks again for your help!
Buz
Buzman63
Postby AstroWill » October 29th 2020, 2:25pm
Here is a great rundown of changes up through 98. https://sites.google.com/site/astrosafa ... -chevy-262
Even if it doesn't apply directly, should give you some ideas of things that have changed over the years. Pump should be the same, but they are so cheap that I would replace the oil pump anyway.
Images: 443
Postby Buzman63 [OP] » October 29th 2020, 8:00pm
Thank you chevymaher and astrowill! There is a TON of info and the link was a wealth of information.. Would the crank need to be swapped to the 94 block for the crank position sensor? That is the only thing I that I'm aware of that may be a problem. (?) My experience with my vansis that something that seems easy and straightforward gets to be a pita. Where something seemingly tough ends up a breeze... Thanks again!
Buz
Buzman63
Postby Mmusicman » October 29th 2020, 8:42pm
Here's how mine looked (just before it went to the curb)..
(surprisingly all the stock front brackets, pulleys, belt, hoses, water-pump, and accys fit my V8 upgrade)
PS: Sorry, no help..
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby chevymaher » October 29th 2020, 9:25pm
yes the crank sensor you need to look into I believe it is a pressed on piece. But the 94 doesn't have that.
Postby AstroWill » October 31st 2020, 9:44pm
If you are using the injection system from the 94, it won't have nor will need the crank position sensor. It just fires the injectors at the same time, they didn't start firing the injectors one at a time in response to the crank position until 96.
Images: 443
It is currently December 4th 2020, 2:40am
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Users browsing this forum: No registered users and 23 guests
