First Gen General Questions
Postby Slime [OP] » November 24th 2020, 11:18pm
Well, as I'm assembling my project I'm finding out what is and is not here. First thing I realized was I have no coil or the mount. Can somebody show me a picture of where that is located on a 1989 4.3? Also, I know one leg of this is broken and it bolts to the intake manifold but what does it do? Guess I'm going to the junk yard soon.
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Slime has been a member for 2 full yearsSlime has been a member for 2 full years
Topics: 17
Images: 7
Alias (AKA): slime
Extra Info: Custom Cargo
  • More (stupid) 1st Gen Questions
    by Slime » December 11th 2020, 6:06pm in Engines
    Last post by Slime View the latest post
    December 12th 2020, 4:27pm
  • Intro/Questions
    by kjkato » January 5th 2021, 8:01am in Engines
    Last post by SportsBoy View the latest post
    January 6th 2021, 12:37am
    7
    65
    January 21st 2021, 4:35pm
Re: First Gen General Questions
Postby AstroWill » November 25th 2020, 12:32am
LOL, that is one way to remove it ;)
Youtube has a bunch of videos of that part under coil replacement.
I probably have a picture floating around here somewhere, will have to look.
Images: 460
Postby Slime [OP] » November 25th 2020, 6:52pm
So, I take it this is the coil mount too?
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 17
Images: 7
Alias (AKA): slime
Postby markmitchmarkmitch is online! » November 25th 2020, 7:02pm
no the coil from the factory is mounted with its own bracket. it sits right behind the throttle body assembly. The item you showed is for the map sensor and another sensor I can't find the name of. The bracket has been cut so grab the bracket from another 4.3 in the junk yard. My advice is find another Astro the same year and engine and take a few pictures to guide you. Anytime I work on another vehicle I am not familiar with I take pictures prior to starting and store them on an external hard drive for future reference.
Firing on 7 Cylinders (L6)
Topics: 623
Images: 20
Extra Info: RS V8 AWD
Postby 90safari » November 25th 2020, 8:46pm
markmitch wrote:no the coil from the factory is mounted with its own bracket. it sits right behind the throttle body assembly. The item you showed is for the map sensor and another sensor I can't find the name of. The bracket has been cut so grab the bracket from another 4.3 in the junk yard. My advice is find another Astro the same year and engine and take a few pictures to guide you. Anytime I work on another vehicle I am not familiar with I take pictures prior to starting and store them on an external hard drive for future reference.
That bracket holds the ESC module (at the top with the exposed terminals) and the map sensor (on the bottom). Here's a crappy pic of it (and location) on my 88 Astro. Sorry about the mess, but I was getting ready to pull the engine, and didn't have a better pic (I looked).
It's located just forward and to the right of the distributor.
This part assembly was used from 1986 thru 92, maybe thru 95 on the TBI engines, and also could be found on S-10's and S-15's with TBI.
I hope this helps.
Note, it's actually located just in front of the coil, and is under that wire cluster mess. It gets bolted to the intake manifold stud and a bolt hole in the manifold, which is probably why yours was trimmed off.
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Postby Leeann_93 » November 26th 2020, 12:39am
This is on my '93 Bravada, so the pic is taken from the front. You can see the coil and bracket on the left.
Slightly closer, but right on the edge on this pic:
And, with the upper plenum removed, you can see the bracket mounting a little better
Postby Slime [OP] » November 30th 2020, 10:22pm
Thanks. I need to make a trip to the junk yard soon..
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 17
Images: 7
Alias (AKA): slime
Postby icebrrg3rd » December 1st 2020, 12:20am
Hmmm, that's interesting. One of my sensors is mounted on a bracket by itself on the back of the head,
the other is next to the TBI on a bracket with a different sensor.
This is a '91 TBI ("Z" motor). Yeah, I swapped in a V-8 but I used the original V-6 sensors and brackets in the original locations.
-Andrew
icebrrg3rd
Topics: 50
Alias (AKA): Andrew
Van Model Year: 1991
Postby Slime [OP] » December 6th 2020, 6:14pm
So, can anybody post a picture of the actual coil and it's mount? I went to Pull-A-Part yesterday only to get the wrong part. This was off a 4.3 ZR-2 S-10. Anybody need this?
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 17
Images: 7
Alias (AKA): slime
Postby Leeann_93 » December 6th 2020, 6:15pm
That's a second gen coil, ICM and bracket.
Taken on an angle, but this is the passenger side of the manifold and head:
And a wider view of the whole replacement engine in the back of my '93, where you can see the ICM is part of the distributor on a Gen 1:
Postby Slime [OP] » December 6th 2020, 6:56pm
Thanks.
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 17
Images: 7
Alias (AKA): slime
Postby icebrrg3rd » December 10th 2020, 12:04am
Best pic I have is for my '91, I guess I've never really took one of just the coil and/or mount.
Mine is mounted between the dizzy and the TBI. Ignore the breather hose that looks like it's attached to it. Two black plugs on one side, and a tower on the other for the plug wire (to dizzy center).
-Andrew
icebrrg3rd
Topics: 50
Alias (AKA): Andrew
Postby Mmusicman » December 10th 2020, 1:53am
Here's what my 92 used to look like... lol
Firing on 7 Cylinders (L5)
Topics: 73
Images: 49
Postby Leeann_93 » December 10th 2020, 2:02am
So is the Astro bracket different from the Blazer/Jimmy/Bravada mount? The pics I posted were from my '93 Bravada and the replacement engine for my '93 Astro, but it came from a '94 Blazer.
Or is it different TBI to CPI?
Postby markmitchmarkmitch is online! » December 10th 2020, 3:38am
Just to clarify he said his is an 89 so he has a TBI engine not CPI. I will take a picture of mine tomorrow , yes I have a 350 but all the brackets are from my original TBI 4.3.
Topics: 623
Images: 20
Postby Slime [OP] » December 19th 2020, 5:59pm
Slime wrote:Well, as I'm assembling my project I'm finding out what is and is not here. First thing I realized was I have no coil or the mount. Can somebody show me a picture of where that is located on a 1989 4.3? Also, I know one leg of this is broken and it bolts to the intake manifold but what does it do? Guess I'm going to the junk yard soon.
So, I found the piece that has broken of this bracket. Is it possible that the missing piece attaches at a 90 degree angle? I do have an aftermarket intake manifold, but I don't really see a way that it fits like that.
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 17
Images: 7
Alias (AKA): slime
Postby markmitchmarkmitch is online! » December 19th 2020, 8:20pm
h=go to a hardware store or home depot grab some steel stock it comes in many sizes and make a bracket to mount it. Just drill the holes in the broken bracket and bolt the home made part to the existing bracket.
Topics: 623
Images: 20
It is currently January 21st 2021, 4:35pm
Date: Jan 10 '21
Time: 7:37pm
roachmonroachmon is online!
Date: Jan 10 '21
Time: 4:04am
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
pmou
Comments: 71
Date: Dec 31 '20
Time: 4:12am
