Drivability Problems
Postby daytonboi [OP] » March 17th 2012, 12:43am
This might be a bit long winded...just a warning.
My van use to get decent gas mileage. Now i'm lucky to get 10mpg. I always figured that my t-stat was bad...it's factory and i'm at 202k miles and it takes almost 2 hours of driving to make any kind of appreciable heat. Haven't changed it cause the ground wire is stuck to the bolt (another story). Also my heat gauge doesn't work, which leads to my problem I'm assuming. Me poking around under the hood I was testing the leads to the temp sensor next to the egr, after being led to believe that was in fact the one that goes to the dash gauge...well it wasn't responding to the test so i plugged it back in and started the van. It started right up, but i had an SES light on, on the dash now. I figured I would after disconnecting the sensor. Next morning i remote started my van and noted that the van was idling kinda high. Then all a sudden the idle went really low. Then it began to run like it was really low on fuel sorta bucking while it was sitting there. It smoothed out in about a minute and I was on my way. But as I was driving the van began to do the same thing, I would be on the throttle and it would almost sorta stall I guess. It would do that a couple times and then it would be ok. SES light still on. I was driving around and it would do that intermittently. The SES light went off. I figured back to normal. Nope it would still buck every once in a while. It's been doing this for two days now and I'm at a loss. I drive for my job so I want to get this fixed as fast as I can. Any help is appreciated. Also I think my alternator is beginning to go...I plan on fixing that next week or so upgrading to an ad244.
daytonboi
Years of Membership: daytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full years
Topics: 35
Alias (AKA): El
Re: Drivability Problems
Postby RECox286 » March 17th 2012, 3:32am
Hey, you know the drill...
First thing to do is upgrade your information to include the year truck you have.
Next thing to do is get a live scan done so you will have a readout of what is going on with the computer & sensors.
Third thing to do is somehow get that T-stat changed out so you will have a warm engine and some cabin heat. The
computer may be in open loop due to the engine temp being too cold.
How long has it been since you did an eyeball inspection of the vacuum hoses ? How about a tune up ? And do you
know if the EGR is working, clogged, stuck open, or what ?
Bad ignition parts, as well as electric leaks are not good for driveability either.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby daytonboi [OP] » March 18th 2012, 4:22am
Thanks for the info... I haven't done the live scan yet i working on buying me a scanner to use with my phone and laptop. But today I did get my thermostat changed out and I do have heat. I also changed my coolant temp sensor that heads to that dash. Now my van is reading almost 260...but i'm not sure if that's right. I did a light flush and drained all the water out and then put more back in, but not the gauges are saying i'm running hot. so I'm not sure if there is air trapped in the system. I've tried burping it but either there is no air in the system or I don't know what i'm doing...and I'm leaning more toward the latter.
daytonboi
Topics: 35
Alias (AKA): El
It is currently October 25th 2020, 5:51am
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
Comments: 61
Date: Oct 09 '20
Time: 2:58am
hankheat
Date: Oct 07 '20
Time: 6:30pm
Users browsing this forum: No registered users and 22 guests
