by justoneman [OP] » March 29th 2021, 2:14am
by Rod's Trucks » March 29th 2021, 7:16am
by rorgeastro » March 29th 2021, 8:01am
by justoneman [OP] » March 30th 2021, 1:20am
Rod's Trucks wrote:That may very well be a very time consuming challenge, but I would first be looking at the ignition system.
The PO has obviously touched the simple bases. You get the knowledge that you have a lot of new parts, so you may have to consider more subtle things, like corroded connections or broken wires..
I cannot think of anything, other than the ignition system, that could make it cut out that randomly, while you still have fuel pressure.
Unfortunately the ignition system connects all parts of the engine control , and related wiring and sensors.
I would head to a JY and salvage any of the modules and sensors that have not already been replaced ( or even some that have been, for later use as spares). try swapping them in, one or two at a time. Visually check every connector and the related wires as best you can, looking for any cracked insulation ( a possible place where corrosion could get to the wire and eat into it)
If it is something that is intermittent It may get worse when wires are moved, or it may go away for a while.
I once had a customer with a nice older Volvo that would suddenly die at apparently random times (except when the mechanics would take it for a test drive...of course). It did not 'run out of gas' kind of die...It just stopped like the ignition was shut off. According to the customer, a tachometer I had temporarily hooked up would instantaneously go to zero.
She finally left it for me for a week while she was on vacation. We outfitted the ignition system with a couple of additional sensors and I agreed to drive it on a 200 mile trip that weekend. It finally died while I was driving it.
We learned the signal from the distributor to the electronic ignition was shutting off when the failure occurred,
We found ( along side a rural road) the wire harness from the distributor went down along the front of the engine and was retained in place by two or three small metal tabs. Under a small layer of old dirt and oil, one on the tabs was slightly loose, allowing the two wire harness to move slightly with the motion of the engine, and it had rubbed thru the protective sleeve and then the insulation on one wire.
It was shorting the ignition signal to the engine block occasionally.
It was an easy fix, once the problem was found.
The point being...nearly anything is possible when it comes to intermittent electrical issues. It is not always a specific component, module, or connector.
It may be a painful trip, but keep us informed as to what you are doing. I am sure others, with more experience, will chime in with suggestions and first hand experience with similar problems.![]()
Rod J
Issaquah WA
by justoneman [OP] » March 30th 2021, 1:23am
Thanks I will check it out as I did notice some stalling on left hand turns. I will just have to go through every little section of all the wiring. At least there is some good weather in my areas forecast. Good laying on my back in the driveway weather.rorgeastro wrote:My 2000 Astro Cargo van stalled intermittently when I first got it.. Usually during turns. It turned out to be a loose side terminal battery bolt. The aftermarket battery had a recessed thread which allowed the short OEM bolt to cam out..it looked tight but wasn't.
by Leeann_93 » March 30th 2021, 1:55am
by justoneman [OP] » March 30th 2021, 2:19am
When I prime the pump it is at 60 psi and then drops down to 56 and holds that after shutting off the engine. I read that 55 was desirable?Leeann_93 wrote:55 psi isn’t enough. Needs to be over 58 and, better, over 60 psi.
by WildBorego » March 30th 2021, 2:29am
justoneman wrote:Hello I just bought a 2004 Astro cargo van. The previous owner spent the past year trying to solve a stalling issue. He informed me he had a shop trying to fix his van. They replaced all the basic sensors, the coil, Distributor cap and wires and plugs. They replaced the main engine control module. They replaced the fuel filter and the catalytic converter and oxygen sensors. None of this has fixed his intermittent stalling problem so he gave up. I bought the van and had it drive fine for a day and then stall on me. It does it at start up. It does it after a while of driving coming to a stop sign. It will do it rounding a corner slowly. It will be fine and the suddenly at speed run badly. I cleaned the throttle body and thought perhaps I had fixed the problem. Not so. I figured it might be a fuel delivery problem since he had not replaced the fuel pump. I ran a fuel pressure test. It is at 55+ pounds. It is that even when the engine stalls out. After shut off the pressure stays up. It is a shame because the engine sounds great when this problem does not rear its ugly head. It starts instantly with the first twist of the key. So I am ready to delve into each possible problem. Not sure where to start though. Any thoughts?
by justoneman [OP] » March 30th 2021, 2:35am
by justoneman [OP] » March 31st 2021, 12:13am
by 02LS1 » March 31st 2021, 12:38am
by WildBorego » March 31st 2021, 2:04am
justoneman wrote:So I suspect I have an electrical issue but in the interest of eliminating fuel issues I have to ask this question to all: Does the fuel pump need to kick out 60 psi for the engine to operate and if I had a leak in the fuel pressure regulator would I not see bleed off with a pressure test?
by justoneman [OP] » March 31st 2021, 2:47am
by Leeann_93 » March 31st 2021, 2:53am
by justoneman [OP] » March 31st 2021, 3:02am
Leeann_93 wrote:No. You have MFI, which is 2002 and up.
by Leeann_93 » March 31st 2021, 3:13am
justoneman wrote:Leeann_93 wrote:No. You have MFI, which is 2002 and up.
Nope CMFI is 1992 to 1995. Just read it in the Haynes.
by justoneman [OP] » April 1st 2021, 2:02am
Leeann_93 wrote:justoneman wrote:Leeann_93 wrote:No. You have MFI, which is 2002 and up.
It’s funny that you think that Haynes is the authority.
CPFI is 1992-1995
CSFI is 1996-2001
MFI is 2002-2005
by Rod's Trucks » April 1st 2021, 4:12am
by AstroWill » April 1st 2021, 8:16pm
justoneman wrote:So this Haynes repair manual is not good! Damn it! How do I get the real information then if I cannot trust the specs in a manual. I guess I can get them from you huh?
by sixsix » April 2nd 2021, 3:14am
Leeann_93 wrote:... CPFI is 1992-1995
Leeann_93 wrote:CPFI is 1992-1995
CSFI is 1996-2001
MFI is 2002-2005
It is currently April 14th 2021, 5:04am
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
