Seeing my damp cap issue came back in a short time I've been giving thought to the problem.
I think I've got a aftermarket dist. I don't have screens, it's got a couple slotted holes. I've drilled them out in the thoughts it would work like removing the screens and I've also slathered the lip with dielectric grease to seal the cap to dist.
Having the splash skirts properly installed is impotent, but I'm thinking that only address's part of the problem. The part I don't think any of us has given thought to is steam flashing off the exhaust. Building a diaphragm that seals off the exhaust from the top of the motor isn't feasible and would probably cause cooling issues.
So here's my thinking. Cut the top vent out of an old school dist. cap and epoxy it into he spider cap, and seal up the vent holes in the dist. base.
What do you think, have I lost my mind, or might I be onto something here.
This is the vent off a Mitsubishi 1.8 I also found top vents on a number of marine caps. like Volvo Penta motors.
