Which wrench to remove O2 sensor 94 Safari
Postby limrick [OP] » May 20th 2012, 10:47pm
I have a 1994 Safari 2 wheel drive with a 3 wire O2 sensor ahead of the Cat.
It's really in a ......... tough spot to get a wrench on.
I need to buy the sensor wrench, but which wrench?
Do I get the sensor socket with offset 3/8 drive, a long extension through the doghouse opening or the flex head sensor wrench and sacrifice a lot of knuckle skin wrenching from below.
anyone done this and remember what they used?
TIA.
limrick
Years of Membership: limrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full yearslimrick has been a member for 12 full years
Topics: 7
  • which year engine ?
    by kazooclown » September 9th 2020, 4:11pm in Engines
    Last post by kazooclown View the latest post
  • which injector cleaner fits Astro misfires over 30mph
    by huddy » September 27th 2020, 5:06am in Engines
    October 19th 2020, 1:57pm
    October 30th 2020, 9:11am
Re: Which wrench to remove O2 sensor 94 Safari
Postby chevymaher » May 20th 2012, 11:29pm
I have a 94 Safari. 7/8 inch long handled wrench from underneath. Mine is angled so the wrench goes on not easy but doable.
Postby Leeann_93 » May 21st 2012, 12:18am
That's what I used on my Bravada, too. Works the best for that application, along with plenty of PB and bracing my legs against the front tire.
I use the offset & regular sockets on my '99, depending on which sensor.
Postby ccookie66 » May 21st 2012, 12:19am
Yeah, I used a wrench...not sure what size. Be careful, when I took mine off it was in there sense birth and it broke the bong thing out with it, had to weld it back in. I would soak it with WD-40 or PB Blaster.
1160
The Astro is always a turn key away from adventure.
ccookie66
Firing on 6 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full years
Topics: 139
Images: 73
Alias (AKA): Cameron
Extra Info: 4.3L V6 TBI Shorty
Postby Phantom » May 21st 2012, 12:23am
Heat helps as well so run engine to heat it up before you try to remove it ,
Phantom
Firing on 7 Cylinders (L4)
Postby ccookie66 » May 21st 2012, 12:37am
Phantom wrote:Heat helps as well so run engine to heat it up before you try to remove it ,
Just don't burn yourself...learned that the hard way. :screaming:
1160
ccookie66
Topics: 139
Images: 73
Postby limrick [OP] » May 21st 2012, 6:14am
Thanks Guys
Gives me a start in the right direction.
limrick
Topics: 7
It is currently October 30th 2020, 9:11am
Time: 11:54pm
Time: 8:41pm
Buzman63
Time: 2:06pm
kade225
Date: Oct 28 '20
Time: 11:27pm
djpigs
Date: Oct 27 '20
Time: 10:01pm
Users browsing this forum: Google [Bot] and 14 guests
