Platinum +4 and other "exotic" spark plugs
Postby powwowtime [OP] » June 27th 2012, 1:04am
Anybody notice a worthwhile difference in performance and/or mileage after splurging for the high dollar plugs?
powwowtime
Years of Membership: powwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full yearspowwowtime has been a member for 8 full years
Van Model Year: 2001
Extra Info: LT
  • Replaced plugs, cap, coil and ICM, now code P0108 is showing
    by tofino » July 4th 2020, 3:48pm in Engines
    Last post by sfeaver View the latest post
    July 6th 2020, 11:18pm
  • Location of engine coolant drain plugs
    by Maddog » September 15th 2020, 10:24pm in Engines
    Last post by Maddog View the latest post
    18
    November 27th 2020, 7:03pm
Re: Platinum +4 and other "exotic" spark plugs
Postby chevymaher » June 27th 2012, 1:14am
Mine runs exactly the same. I just don't have to change them as often.
Postby Jasen » June 27th 2012, 3:46am
I played with hose mutli electrode plugs when they first came out, had nothing but trouble with them. I run NGK Iridium's, no difference in performance, but I don't have to change them for 60k miles of so.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby RECox286 » June 27th 2012, 4:20am
I like the Bosh plus fours. Not like putting 2 plugs/cyl, but they do the job, and for a lot longer mileage interval. Changing plugs is like me
pulling my own teeth. (not a favorite job here at gasoline alley)
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Matrixx » June 27th 2012, 9:52am
For me personally it's been Ac Delco Platinums - Bosch Platinums - and my current plugs are the NGK Iridiums. All of these plugs work well, my preference are the Iridiums though, the only beef I have with them is they sometimes work loose at around the 50,000 mile mark.
I just check them and snug them up if need be at that point. I still feel they are worth the money though. I have noticed a slight improvement with gas mileage and performance with my engine (every little bit helps).
As for the Platinum +4s, I have never run them, so I can't give an opinion about them.
Just my 2-cents here for what it's worth.:)
Matrixx
Postby Leeann_93 » June 28th 2012, 1:20am
I like the AC Delco Iridium plugs. Same part number as the old Platinums; they've just replaced them.
Oh, and they definitely made a difference in both my '99 Safari and my 'new' '02 Astro. The Safari had Champion coppers in them (!) and the Astro had Autolite Platinums.
Postby 88astroLT » June 28th 2012, 5:01am
I've used Bosch Platinum Plus, and Bosch Platinum +2. Never tried Platinum+4. But performance is just as good as ACDelco in my opinion. The platinum +2 just lasts longer than the Platinum Plus. No change in performance.
88 Astro LT RWD 343k+ 3.23
97 Safari SLE RWD 143k+ 3.42 Limited Slip
88astroLT
Years of Membership: 88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years
Topics: 19
Extra Info: LT 4.3L V6 RWD
Postby Lumpy » July 8th 2012, 7:11am
Bosch has a rebate going on right now that makes the final price of +4 plugs around 50 cents each.
Postby ihatemybike » July 9th 2012, 4:35pm
I'm currently using the Bosch Platinum +4 plugs in Green. Not sure how much benefit there is to them as I have a few other mods done. Overall I'm happy with them.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full years
Topics: 68
Postby astro1957 » July 9th 2012, 5:38pm
The previous owner of my Astro put Autolite double platinums in it,right before I bought it.Doesn't Ford make these things :oops: ? I guess they have a 5 year,unlimited mileage warranty,according to the sales receipt.I've always used AC Delco plugs/parts in all my GM vehicles.They cost more,but peace of mind is worth it.This van will get them eventually,when I do a tune up.
1996 Astro - SMc by Archer Conversion-
A friend is not a fellar,who is taken in by sham.A friend is one who knows our faults,and doesn't give a dam.-J.P. McEvey
astro1957
Years of Membership: astro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full yearsastro1957 has been a member for 8 full years
Van Model Year: 1996
Postby chevymaher » July 9th 2012, 5:58pm
astro1957 wrote:The previous owner of my Astro put Autolite double platinums in it,right before I bought it.Doesn't Ford make these things :oops: ? I guess they have a 5 year,unlimited mileage warranty,according to the sales receipt.I've always used AC Delco plugs/parts in all my GM vehicles.They cost more,but peace of mind is worth it.This van will get them eventually,when I do a tune up.
That what I run in mine. I never have a miss. I can't ask more out of a plug.
I have used autolite forever. Nobody sees them once the spark plug boots on. Besides Furd can't do everything wrong. They got a good plug.
Postby astro1957 » July 9th 2012, 6:13pm
Well that's good to hear Chevymaher.Maybe I'll stick with Autolite in this van.He was the original owner,I suppose he liked them too.My wife says I'm an old dog who doesn't like change,I get stuck in my ways from the past.Never to late to try something different I guess,including spark plugs...: )
astro1957
Postby Lumpy » July 9th 2012, 7:09pm
chevymaher wrote:
I have used autolite forever...
I put Autolites in my van and they caused my dome lights to burn out quicker.
Postby chevymaher » July 9th 2012, 9:01pm
astro1957 wrote:Well that's good to hear Chevymaher.Maybe I'll stick with Autolite in this van.He was the original owner,I suppose he liked them too.My wife says I'm an old dog who doesn't like change,I get stuck in my ways from the past.Never to late to try something different I guess,including spark plugs...: )
Just wait till it misses to change them. Heck in a hundred thousand miles you'll think these ain't bad plugs. Like Lumpy said just got to keep a good supply of dome light bulbs. So I guess it give and take. :rofl: :rofl: :rofl:
It is currently November 27th 2020, 7:03pm
djpigs
Comments: 42
Time: 11:23pm
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
Users browsing this forum: Google [Bot] and 10 guests
