92 astro idle rough, surging, backfiring
Postby compfreak [OP] » October 6th 2008, 3:50am
I just got a 92 astro van from my dad and while idling it vibrates the whole van very badly. enough to give me a headache. while driving if i hold it at a steady throttle i can feel the van surge pretty badly, also while going up steep inclines it backfires out of the intake.. its a TBI i believe, i just changed the fuel filter i was told the spark plugs were changed less then a year ago. it sat for about 3 years. before that it ran and idled fine but still backfired. its the v6 and has 130k miles i dont know anything about these vans, any help would be very much appreciated
compfreak
Years of Membership: compfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full yearscompfreak has been a member for 12 full years
  • Hard Cold Start and Rough Idle. No Codes. Diagnosis?
    by AstroTan » October 17th 2020, 5:26am in Engines
    November 28th 2020, 1:10am
  • Intermittent rough idle, stalling
    by 95AstroLT » October 21st 2020, 4:50pm in Engines
    November 11th 2020, 10:33pm
    9
    55
    December 4th 2020, 3:23am
Re: 92 astro idle rough, surging, backfiring
Postby gtkane » October 7th 2008, 3:27am
There are a number of things that it could be.
1. vac leak. The gasket under the throttle body is known to crack,causing a leak, and will give those symptoms.(usually has high idle as well)
2. Corrosion in the cap and rotor. Causes misfiring and surging.
3. EGR valve stuck open. Carbon plugs it up.
4. Low fuel pressure. Could be caused by weak fuel pump, or by a faulty fuel pressure regulator.
I would check these in this order first.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby compfreak [OP] » October 7th 2008, 7:06am
What is the best way to change the gasket on the thottle body? just pull the cover inside and go from there? also where might the egr be located?
compfreak
Postby Gary » October 7th 2008, 11:38am
Go with delco cap and rotor first.Do delco wires as well.Do that before you do anything else.Tell us how you made out then.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
It is currently December 4th 2020, 3:23am
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Users browsing this forum: No registered users and 21 guests
