temp gauge issues
temp gauge issues
Postby ccookie66 [OP] » August 7th 2012, 4:39pm
I just replaced my coolant temp sensor for the gauge. Now when the engine is running, the needle slowly creeps up to H in a matter of seconds. Then it just sits there on H. Why is it doing this? I'm sure the engine is really that hot.
1160
The Astro is always a turn key away from adventure.
ccookie66
Firing on 6 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full years
Topics: 139
Images: 73
Alias (AKA): Cameron
Extra Info: 4.3L V6 TBI Shorty
Re: temp gauge issues
Postby ccookie66 [OP] » August 7th 2012, 6:12pm
Wait, is there suppose to be two wires coming from that sensor? Right now, the new one has the same connector as the coolant temp sensor for the computer. There is a yellow wire and a black wire coming from the new sensor. But then there is only one green wire which was hooked to the old sensor. So I connected the green wire to the yellow, then the black one to the body, the gauge slowly goes up to H when the key is turned to ON. :shrug: I don't know now where to start. I guess my van is running hot....I hope I don't need to get a new thermostat. :banghead:
1160
ccookie66
Topics: 139
Images: 73
Postby chevymaherchevymaher is online! » August 7th 2012, 7:37pm
It should only have one wire.
Postby ccookie66 [OP] » August 7th 2012, 8:35pm
Oh. It has two. I just connected the black ground to the body and left it that way. Now when I start it, it shows the right temp, then it just goes up to H in a few seconds. .
1160
ccookie66
Topics: 139
Images: 73
Postby ccookie66 [OP] » August 7th 2012, 9:47pm
Its messed up again, back at C. I'm just going to leave it. I can never get the right one. All the ones I ever get have two wires. I drove it for like 5 years without it working, nothing happened. So I just left it alone. Why do they keep giving me the wrong one? NAPA said it has two wires, and Advanced gave me one with two wires. What gives? I know it has one wire, I have seen it. All there is is one wire. How can there be two? :shrug:
1160
ccookie66
Topics: 139
Images: 73
Postby 94 Van Guy » August 7th 2012, 10:28pm
chevymaher wrote:It should only have one wire.
What Randy said.
Are you sure they aren't getting mixed up with the one for the computer?
'91 Chevy G30 Bus 39.3K Miles
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 5 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years
Topics: 71
Images: 44
Alias (AKA): Keith
Van Model Year: 1991
Extra Info: G30 Bus
Postby ccookie66 [OP] » August 7th 2012, 10:36pm
I told them! I said, "There are two, one for the computer, and one for the gauge, I want the one for the gauge" they said yup and got the wrong one! :banghead: I wounder if I can find one online, like ebay.
1160
ccookie66
Topics: 139
Images: 73
Postby 94 Van Guy » August 7th 2012, 10:44pm
Rock auto does have them but just try to find them...
Read on!
Good luck,
Keith
EDIT I will find the one I used
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 71
Images: 44
Alias (AKA): Keith
Extra Info: G30 Bus
Postby ccookie66 [OP] » August 7th 2012, 10:54pm
But look, it has two little prongs inside it. Doesn't it only need one? One for the one wire? http://www.rockauto.com/getimage/getima ... &width=450
This is the one you where talking about? http://www.rockauto.com/catalog/moreinfo.php?pk=1111888
If so, than that is the same exact one I have.
1160
ccookie66
Topics: 139
Images: 73
Postby 94 Van Guy » August 7th 2012, 11:02pm
I have been looking and your correct.
I am going to edit my previous post.
Thanks for the heads-up
Keith
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 71
Images: 44
Alias (AKA): Keith
Extra Info: G30 Bus
Postby ccookie66 [OP] » August 7th 2012, 11:11pm
This is the connector http://www.napaonline.com/Catalog/Catal ... 0210013741 I have connected to this sensor http://www.napaonline.com/Catalog/Catal ... 0348773557. I have that yellow wire connected to the only wire I can find, which is green. I then have the black wire connected to the body, grounded.
1160
ccookie66
Topics: 139
Images: 73
Postby chevymaherchevymaher is online! » August 7th 2012, 11:31pm
This is what the sensor looks like. The plug and sensor your showing are for the computer. This is in my extra set of heads. Same as my 90 had. Same as my 94 has. I will go look at advance and see if I can get a part number after this post.
Postby 94 Van Guy » August 7th 2012, 11:45pm
found this one.
Seems it is called a Engine temp sensor.
http://www.autopartswarehouse.com/detai ... S253T.html
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 71
Images: 44
Alias (AKA): Keith
Extra Info: G30 Bus
Postby 94 Van Guy » August 7th 2012, 11:59pm
Coolant Temperature Switch,GM 08993146
or
http://www.ebay.com/itm/ACDELCO-D1885-C ... 0716275724
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Topics: 71
Images: 44
Alias (AKA): Keith
Extra Info: G30 Bus
Postby ccookie66 [OP] » August 8th 2012, 2:10am
94 Van Guy wrote:found this one.
This is the one that will work. Now all I need is the connector. All there is is a wire dangling there. :ty:
1160
ccookie66
Topics: 139
Images: 73
Postby ccookie66 [OP] » August 8th 2012, 2:12am
Freakin Advanced Auto parts, they won't take back the sensor! They gave me the wrong one, and the least they can do is take it back and give my money back...but no. They said it was for the gauge, and its not! Its for the computer! :banghead:
1160
ccookie66
Topics: 139
Images: 73
Postby chevymaherchevymaher is online! » August 8th 2012, 2:19am
ccookie66 wrote:This is the one that will work. Now all I need is the connector. All there is is a wire dangling there. :ty:
This is a old school gauge and sender. It don't have to be anything fancy installed on the 3rd equinox of a blue moon, with dielectric grease in a counter-clockwise fashion. It just got to touch and it works. No new and improved computer involved with its sensitive electronics.
Radio shack my boy. Sells spade connectors. Stick the wire in squeeze it. Plug it in. Probably cost you all of 30-50 cents.
Go online file a complaint with the better business bereau they will take it back. It was there fault.
Postby ccookie66 [OP] » August 8th 2012, 2:23am
But there are two prongs in there, a smaller one and a normal one. What do they do? Which do I hook the wire to?
1160
ccookie66
Topics: 139
Images: 73
Postby chevymaherchevymaher is online! » August 8th 2012, 2:30am
ccookie66 wrote:But there are two prongs in there, a smaller one and a normal one. What do they do? Which do I hook the wire to?
Wow I thought this was settled. Get the right sending unit. That is the wrong one. ONE WIRE SENDER.
Postby ccookie66 [OP] » August 8th 2012, 2:33am
No, see look! It has a tiny one too. What is that for? There is a big prong, and a tiny one. http://images.apwcontent.com/is/image/A ... W_imgProd$
1160
ccookie66
Topics: 139
Images: 73
It is currently August 10th 2020, 1:10am
pmou
Comments: 38
Date: Jul 30 '20
Time: 3:31am
pmou
Comments: 38
Date: Jul 29 '20
Time: 11:58pm
Attached by: tonydobbs
tonydobbs
Date: Jul 29 '20
Time: 5:41pm
pmou
Comments: 38
Date: Jul 21 '20
Time: 7:13pm
pmou
Comments: 38
Date: Jul 20 '20
Time: 11:50pm
