No start
No start
Postby daytonboi [OP] » August 28th 2012, 9:24pm
Help...my van is in a bad way right now. Let me start at the beginning. About two weeks ago I replaced the cap, rotor and coil. Everything thing has been just fine with an occasional bit of hesitation. Fast forward to today I was out driving everything was fine, I had just put $20 worth of Shell gas in it and about 20 minutes later I was driving and went to accelerate and the van lost all power and started to buck and then sounded like it was maybe running on 1 to 3 cylinders from the feel of it. I pulled off the roadway and tried to go up an almost non existent incline and the van couldn't do it, it just died. Right afterword i could get it running by keeping the throttle mashed to the floor and even then the engine would buck really hard. I tried shooting ether down the intake and the engine would turn over but it would die right back out. What can be wrong with this beast? I need her for work tomorrow so any help would be appreciated.
Oh yeah no SES light.
daytonboi
Years of Membership: daytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full yearsdaytonboi has been a member for 11 full years
Topics: 35
Alias (AKA): El
Re: No start
Postby Ragenme » August 28th 2012, 10:13pm
Sounds like the fuel pump is trying to die.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Extra Info: SLX 4.3 V6 RWD
Re: No start
Postby daytonboi [OP] » August 28th 2012, 10:36pm
please don't tell me that, it was just replaced about 2 yr ago
daytonboi
Topics: 35
Alias (AKA): El
Re: No start
Postby Rolling_Rock » August 28th 2012, 11:53pm
Do the basics:
1) check fuel
2) check spark
start with #1 and post up your reading from your fuel pressure guage
Rolling_Rock
Years of Membership: Rolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full yearsRolling_Rock has been a member for 9 full years
Topics: 26
Van Model Year: 2002
Extra Info: cargo version
No start
Postby Astronaut87 » August 29th 2012, 2:58am
I'd try an EGR block-off plate. Your problem kinda sounds like how mine was running, and that's what fixed it. The EGR valve was sticking open and making it run like cat ****. Good luck!
Cory
87 Astro rwd
400hp TBI 383/Built 700R4/12-bolt Posi
Daily driver, stoplight toy, tow rig
Astronaut87
Years of Membership: Astronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full yearsAstronaut87 has been a member for 8 full years
Topics: 5
Images: 25
Alias (AKA): Cory
Van Model Year: 1987
Extra Info: TBI383 700R4 RWD
Re: No start
Postby daytonboi [OP] » August 29th 2012, 3:28am
Well I got it running. That POS Accel distributor cap and rotor destroyed itself. The rotor burned a hole through itself and the cap melted.
daytonboi
Topics: 35
Alias (AKA): El
Re: No start
Postby chevymaher » August 29th 2012, 3:37am
daytonboi wrote:Well I got it running. That POS Accel distributor cap and rotor destroyed itself. The rotor burned a hole through itself and the cap melted.
I am impressed thats some serious voltage. Welder spark to the plugs. No gap needed jumps straight to the piston.
Re: No start
Postby RECox286 » August 29th 2012, 4:08pm
Is that what Chevy calls the UHEI ignition system ? Hee hee. (Haven't heard of that one before.)
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently January 17th 2021, 9:33am
Date: Jan 10 '21
Time: 7:37pm
roachmon
Date: Jan 10 '21
Time: 4:04am
roachmon
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
pmou
Comments: 71
Date: Dec 31 '20
Time: 4:12am
