80psi fuel press readings
Postby TurboPirate [OP] » September 24th 2012, 9:23pm
Hello everyone at this awesome forums, I justt bought a Chevy Astro 1996 on November the previous owner installed new ac delco assembly fuel pump with sender strainer etc. Now it is a pain to start the engine, I turn key engine cranks but takes to long to fire up, I check fuel press and its at 80psi at idle, 70psi at 50% TPS or WOT, I check the return line at idle and there is fuel, any help is apreciated.
P.S. is a Vortex engine with the fuel press tool if I press the release port and manage to lower press to 50 engine works perfectly....thanks in advance Turbo
TurboPirate
Years of Membership: TurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full yearsTurboPirate has been a member for 7 full years
Alias (AKA): Gregory
Van Model Year: 1996
Extra Info: 4.3L 4L60
Re: 80psi fuel press readings
Postby chevymaher » September 24th 2012, 10:08pm
Makes sense your fuel pressure should be 58-62 range. Pressure regulator not working right, something partially blocked etc, etc.
Postby TurboPirate [OP] » September 25th 2012, 3:58am
Thanks, I am planing on removing the return line and adding a hose to portable gas tank, start the engine and see if the pressure goes to proper reading, this way I'll look at the return line to see if there is something blocking the flow, if fuel press is still high then I'll remove upper intake manifold and see if the problem is fuel press regulator, thanks in advance Turbo
TurboPirate
Postby TurboPirate [OP] » September 26th 2012, 12:32pm
Ok guys did the test with return line removed to a portable gas tank andtried all worked perfect at 55psi, used a air gun blowed intio return line and air did not pass freely, took gas tank down and the flare twisted the metal tube, who ever installed the fuel pump waas not careful and wile it was tightening the flare didn't notice tube was turning to, I cut the damage area used new hoses. Tested with gas tank on the floor all worked perfect, installed everything back re tested fuel press @55psi @ idle 60psi with lower vac at intake, thanks in advance Turbo
TurboPirate
It is currently September 21st 2020, 3:18am
Maddog
Comments: 31
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:47pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:43pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:40pm
erikw9
Comments: 37
Date: Sep 14 '20
Time: 7:30pm
Users browsing this forum: No registered users and 20 guests
