Which brand for replacing certain critical parts
Postby gamefreak [OP] » October 8th 2012, 6:07am
I got a 1994 Chevy Astro from my deceased grandmother last May. Since getting the van I replaced the Radiator, Fan Clutch, Fuel Pump and did a complete tune-up. For the tune-up and fuel pump I stuck to AC Delco and Delphi parts. My van still rough idles and I do still get a smell of gas. However the black exhaust no longer comes out of the tailpipe. My MPG also went up from 11 to 16, noticeable improvement. The van still runs Rich and I need to get the fuel mixture just perfect. My oil also turns pitch black after only 1,000 or so miles of driving.
I still have a ways to go to make this van run like a dream though. My fuel gauge now stays stuck at 1/4 of a tank and now officially doesn't work. Which probably means I have to replace the fuel sending unit. I also still have to replace the EGR valve, the Cat Converter and possibly the Fuel Lines in the spider. There is also still a possibility I will have to replace the fuel pressure regulator and the injector inside the spider. While I'm at it I may want to make sure the Idler Air Control is cleaned out.
When I replace these parts should I stick with AC Delco based parts or could I just go with any brand the auto parts stores carry. I know with fuel pumps and tune up related parts you should stick with AC Delco/ Delphi.
gamefreak
Years of Membership: gamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full years
Topics: 7
  • which year engine ?
    by kazooclown » September 9th 2020, 4:11pm in Engines
    Last post by kazooclown View the latest post
  • which injector cleaner fits Astro misfires over 30mph
    by huddy » September 27th 2020, 5:06am in Engines
    October 19th 2020, 1:57pm
    61
    December 4th 2020, 5:35am
Re: Which brand for replacing certain critical parts
Postby beazleybub » November 26th 2012, 4:45am
For the last 11 years I have worked for a large auto parts distributor as a truck driver.
I can tell you from experience that I pick up an equal percentage of defective parts from all the major parts suppliers.
There is really no clear cut choice because most all parts are manufactured using the same technology. Some parts are manufactured and sold to various companies with the only difference being the name stamped on them. For example, When I pick up battery cores from some of my stores on my route, I'll see "Ford" and "Lexus" branded batteries even though they are most likely manufactured by companies like exide.
1997 Chevy Astro 4.3L RWD 230,000 Miles and been to Germany
1997 Chevy Astro 4.3L AWD 205,000 Miles and Possessed
beazleybub
Years of Membership: beazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full yearsbeazleybub has been a member for 8 full years
Alias (AKA): beazleybub
Extra Info: 1997 Astro 4.3L RWD
Postby ccookie66 » November 26th 2012, 5:14am
Depends on how much you wanna spend really. With me, I get the lowest price parts. Sometimes they last, sometimes they don't. It just a gamble.
1160
The Astro is always a turn key away from adventure.
ccookie66
Firing on 6 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full yearsccookie66 has been a member for 8 full years
Topics: 139
Images: 73
Alias (AKA): Cameron
Extra Info: 4.3L V6 TBI Shorty
Postby RECox286 » November 26th 2012, 5:37am
For some parts, brand does make a difference. Try to stay away from anything autopartwise made in China. Any other COO
is heads above cHINA to be sure. If you stick with dealer parts, you will most likely be getting the same (cheapest) supplied
items that the car was built with, and went bad with. Still, they are a valid choice to be sure. LAPS usually have one or possibly
more than one brand that they stock or can order from the warehouse. I usually get the best (more expensive) parts I can
find at the LAPS, and that too can be a crap shoot. Pay yer nickle, take yer choice. You get what you pay for, and you pay
for what you get.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently December 4th 2020, 5:35am
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Users browsing this forum: Google [Bot] and 18 guests
